busted my gas tank.
Old Mar 13, 2010 | 10:44 AM
efhondaracer27's Avatar
Default busted my gas tank.
long story short, going down the road car in other lane metal object in mine. put a crack in my tank. so the question is what can i do? i have a wrecked 90 si crx and my car is a 90 civic dx, can i swap the tanks? or should i just try to jb weld it or something to that extent.. any help would be great.
Old Mar 13, 2010 | 11:28 AM
miguey310's Avatar
Default Re: busted my gas tank.
i don't think the crx tank would work cause its alot smaller
Old Mar 13, 2010 | 11:51 AM
scottmog's Avatar
A lot smaller? How much does a civic tank hold? The crx si is like 10.5 gallons and crx dx/hf is around 8-9 gallons
Old Mar 13, 2010 | 12:07 PM
Eddie Z's Avatar
you can get a new tank for under 100 bucks now well it wood be aftermarket but jb weld will not work and crx and hatch tanks are difrent
Old Mar 13, 2010 | 12:14 PM
DCRB's Avatar
honda show's that the gas tanks are the same part number. the HF had a smaller tank but dx's and si's had the same size tank. o/p, YES you CAN use the tank from your wrecked si
Old Mar 13, 2010 | 12:20 PM
jrose152's Avatar
whats the worst that could happen, since both cars arent running, try and put it on, if it dont work then buy another
Old Mar 13, 2010 | 01:01 PM
Eddie Z's Avatar
well if the part numbers are the same yous it i just new my hf was dif sorry im not a honda parts catilog
Old Mar 14, 2010 | 06:29 AM
EFRue57's Avatar
they do make repair kits that i have used before successfully. however, since you have the wrecked Si, i would use it. it will swap over.
Old Mar 14, 2010 | 08:46 PM
89crxsi89's Avatar
the guy who i bough my car from drilled 3 holes through the chassis into the gas tank to secure his amp's. smart huh? until he took them out. as i was driving away, you can imagine what I smelled. I got a gas tank from a wrecking yard for 65 bucks. I would save your self the time and just buy one...
Old Mar 14, 2010 | 08:49 PM
BiG ChOr!Zo's Avatar
WRONG.
jb weld does work on repairing a gas tank...i got a hole in my cutlass when i was hitting switches back in 2004 and used jb weld to the rescue...its been holding fine ever since...!!!
Old Mar 14, 2010 | 09:00 PM
ryanevansoh's Avatar
Originally Posted by BiG ChOr!Zo
WRONG.
haha im sure it works but i dont think its meant to be a permanent solution. id just get the new tank
Old Mar 14, 2010 | 09:05 PM
looks and seals just like new...if it aint broke (anymore) why replace it
Old Mar 14, 2010 | 09:08 PM
haha guess that makes sense
Old Mar 14, 2010 | 09:15 PM
for anyone not smart make sure you use this kind of weld
and not this kind
when patching up a gas tank...!!!
Old Mar 15, 2010 | 08:31 AM
Hondaisok's Avatar
and not this kind
I've also successfully used on my current honda gas tank some other stuff you can get at Walmart, etc. call seal all or something like that.
BoostedEF
May 22, 2008 01:48 PM
crxhf15
Feb 1, 2008 04:34 AM
FOMULA91
Feb 1, 2005 01:15 AM
c9r0x
27
Sep 9, 2003 11:59 AM
Mr Boston
Apr 20, 2003 12:09 AM
