What the hell?!?!?!
Old Mar 13, 2010 | 10:28 AM
Teamdiesel's Avatar
Default What the hell?!?!?!
I was just installing a braided line in my block for my oil pressure gauge when I noticed this. Now the crack does not move or get bigger as I thread the fitting, and the threading goes deeper into the block than the crack. My question is what do I do about this and if I run the car as is, will it be ok?
Old Mar 13, 2010 | 11:20 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: What the hell?!?!?!
if it doesn't leak, you could always try putting J-B weld on it.
Old Mar 13, 2010 | 11:24 AM
00b18b's Avatar
Looks like you used a NPT(tapered) fitting, which caused for the crack. You got that sucker almost to the hex. You should have used a BSPT(non tapered) I believe? Anyhow too late...you may be fine for now. But who knows with engine vibrations the crack may expand? The block material does get thicker in the direction of the crack so it may not expand... If it were me I'd pull it out,weld, tap, get new fitting.
Old Mar 13, 2010 | 11:40 AM
mouab18c1's Avatar
Jb Weld works great. I had the same problem before and welded that sucker with Jb weld. It holds fairly good. Just apply a small amount at a time and let it dry up really good before adding more layers.
Old Mar 13, 2010 | 11:42 AM
Teamdiesel's Avatar
The end that is threaded in the block is not tapered at all. J-B weld seems to be the next option for now...thanks 00Red_sir.
Old Mar 13, 2010 | 11:46 AM
Teamdiesel's Avatar
It's this one right? J-B Weld 8265-S Cold Weld.
Old Mar 13, 2010 | 12:03 PM
Eddie Z's Avatar
yes jb weld will work to hold the craked part together but it will not hold oil back so if it is leaking fix it now becuz if it duz come out it will empty the oil pan relly qwick and why take a chance on blowing it up. if this helps honda v6 blocks have oil seeping problums and thay recumend us to yous it to fix them
alex1320
Dec 18, 2012 04:57 PM
acuralovar
Oct 20, 2008 05:00 AM
drintegra
May 1, 2006 10:45 AM
JR Integra
Sep 27, 2004 12:27 AM
1genCL
Jun 2, 2003 04:42 AM
