since pm6 ecu can be socketed... what about pr3?
Old Mar 13, 2010 | 06:17 AM
Charlie Moua's Avatar
Default since pm6 ecu can be socketed... what about pr3?
until recently I didn't even know that the OBD0 pm6 (si) ecu could be socked/chipped for turboedit.
So I figure why wouldn't a PR3 ecu from 90-91 DA?
Anyone know for sure?
Old Mar 13, 2010 | 06:34 AM
DEIVIONCRX's Avatar
Default Re: since pm6 ecu can be socketed... what about pr3?
Only the 90-91 PM6 can be chipped. Im not sure about the PR4.
Old Mar 13, 2010 | 06:52 AM
My brother has b20b in his DA (h-i-e) and wants to get the most out of his current setup.
Aside from spending money to convert to obd1.
Since the pm6 can be chipped.... do you know anyone that makes a ideal fuel/timing map for B20b ?
Old Mar 13, 2010 | 07:29 AM
crx_si-r's Avatar
Yes the pr3 can be chipped, I used to have one. I gad it running my lsv, so I don't see why the pm6 couldn't be.
Old Mar 13, 2010 | 07:35 AM
is it just like socketing obd1 ecu boards?
Old Mar 13, 2010 | 08:55 AM
raene's Avatar
It's almost easier. The chip itself has to be cut off, which kinda sucks, but then all you have to do is put the socket in and put a good bin in it. There's zero extra work to do IIRC (it's probably been 4-5 years since I socketed an OBD0 ECU).
Old Mar 13, 2010 | 08:11 PM
anyone have a link or "how to" guide?
Old Mar 13, 2010 | 09:15 PM
raene's Avatar
Use an exacto knife to cut the legs off the chip and then clean it up afterwards, or use a solder sucker to suck the solder out of the holes around the legs, then solder in a socket. That's really all there is to it
Unless someone else has a better way of doing it, I'm not a pro!
Old Mar 13, 2010 | 09:23 PM
Deetz's Avatar
Crazy Honda Guy
Just a heads up, the PR3 ecu came in "both" obd0 and OBDI formats.
Personally, and i think others will agree, i'd say do an obdI conversion....there are many benefits!!
- the obdI ecu's operate at twice the speed...more efficient
- better idle quality
- better fuel consumption
- super easy to chip...almost unlimited options for tuning
Old Mar 14, 2010 | 05:18 AM
Sikocivic's Avatar
I have used TurboEdit for years on my old Hatch. Its not a very good program. It was great when it came out because it was all we had. I never could get the "off boost" part of the maps to be correct, always ran too rich. It may work on the B20 but I am sure you would have to make your own base map to get it running and then tune from there. I would tell you to go with the OBD1 conversion. It may be a few bucks more money but you get so much better tuning options.
My old Hatch is getting converted to OBD1 right now.
Old Mar 14, 2010 | 08:50 AM
Radim's Avatar
90-91 PM6s can be chipped, PR3s can be chipped, PS9 ECUs can also be chipped.
shortshift89
Aug 29, 2007 06:31 AM
prestidge81
Jul 18, 2007 12:47 AM
InJ3cted
Apr 25, 2005 06:57 PM
dohcnotec
Sep 3, 2004 09:09 AM
