a clunking noise and vibration!?!?help.
Old Mar 12, 2010 | 10:30 PM
tealchief's Avatar
Default a clunking noise and vibration!?!?help.
so i have been addressing a problem that progressively got worse. my car was clunking pretty bad at any speed after 25, but only when i held the wheel straight, i also got vibration under braking and the same clunk whenever i hit a bump.
Progress : new axle, replaced new inner and outer tie rods that were tore up, and a alignment.
now the clunking noise has moved up 45+mph, but still get vibration during braking, and still hearing a thud noise when i go over larger bumps.
any help would be greatly appreciated. I'm having no fun driving this car as of now.
i think its maybe a bent front rim, halfshaft? f'ed trans?
Old Mar 13, 2010 | 12:07 AM
boxeocampeon's Avatar
Default Re: a clunking noise and vibration!?!?help.
could be a bent rim, rotor, or hub. are your lug nuts on all the way? actually two of my ****ing lug nuts popped off today with the studs so i would check that
Old Mar 13, 2010 | 12:10 AM
chipo22's Avatar
TRIAL USER
how can a bent rim make the noise?
Old Mar 13, 2010 | 08:38 AM
tealchief's Avatar
lug nuts are def. tight, and a bent rim would be a good candidate since it would wobble while moving if it was bent. there has to be something dumb im not realizing..
Old Mar 13, 2010 | 10:19 AM
Red_Army's Avatar
is the thud just your shock towers hitting the top of the wheel well? like that kind of noise?
id have to say check your rotors for that vibration.
no idea on the clunking though.
Old Mar 14, 2010 | 12:42 AM
tealchief's Avatar
ttt
Old Mar 14, 2010 | 12:59 AM
bsmith100's Avatar
If the rear trailing arm bushings are worn out you are likely to hear a clunk when you hit a bump at any speed. You won't hear the clunk until you hit a bump.
Vibration that only occurs under braking sounds like a brake problem. Replacing the rotors and brake pads might fix this.
Old Mar 14, 2010 | 10:18 AM
tealchief's Avatar
all of the noise is coming from the front.. trying new rims today..
Old Mar 14, 2010 | 11:06 PM
bsmith100's Avatar
If the clunk is coming from the front then it could be the front compliance bushings. They also have been known to wear out and cause a clunking noise when hitting a bump.
Old Mar 15, 2010 | 09:28 AM
tealchief's Avatar
ttt, rims are fine, compliance bushing is a good idea still have to check those, only thing is that it feels like the clunking is coming from the whole front end not just pass. or drivers side, any other ideas?
Old Mar 15, 2010 | 04:28 PM
EJ1civic coupe's Avatar
in need for answers to..i have the same exact problem..just started happening to me not to long ago..
Old Mar 15, 2010 | 05:44 PM
1 sLoW hAtCh's Avatar
There vibration during braking is definetly your rotors being warped, replace your rotors and pads, or get your rotors resurface if it's blank rotors and is not at it's minimum thickness and replace pads. The front clunking noise, I wanna ask if you have front sway bar? If you do, then it might be your front sway bar bushings and end links that's making the clunking noise when going over bumps. When the bushings wear it really isn't holding the sway bar firmly so when you hit a bump it makes a clunking noise, you can try with that if you have front sway bar.
Old Mar 15, 2010 | 11:43 PM
tealchief's Avatar
i have no sway bar, it doesn't feel like a warped rotor to me
Old Mar 15, 2010 | 11:53 PM
SoL_ger's Avatar
i had the same problem on my del sol.. it was my rotors. i just got a brake service then it was fine.
Old Mar 16, 2010 | 05:30 PM
tealchief's Avatar
ttt.
Old Mar 17, 2010 | 07:40 AM
tealchief's Avatar
teh bump
flyinfree
Jan 17, 2012 06:49 AM
aaronISthrowed
Oct 31, 2006 03:32 PM
Del Souless
Aug 12, 2004 10:22 PM
CNSK
May 29, 2004 09:31 PM
Ronin Integra8
Dec 14, 2002 04:16 AM
