High Compression Turbo CRX on E-85
Auto Addictions new (daily driven) high compression turbo CRX. Running on
E-85 ethenol with custom injectors from Kinsler Fuel Injection, and an Auto Addictions custom topmount T3 minifold.
- B18C1 GSR block
- 81.5mm bore
- 95mm Eagle stroker crank
- Stock B16 head and cams
- 13.2:1 compression
- Kinsler Fuel Injection modified 800cchigh impedence injectors
- Auto Addictions custom topmount turbo manifold
- 50 trim turbo @ 10 psi
- Auto Addiction custom backdoor intercooler
- Tial blow off valve
- Tial 38mm wastegate
**special thanks to Scott at Kinsler Fuel Injection**
**** CHECK BACK FOR DYNO VIDEOS!!! ****
- B18C1 GSR block
- 81.5mm bore
no dyno #s yet
comes up really fast and spinss the tire on my dyno 3rd and 4th gear. and not to worried about the compression , just keeping it a little rich to be conservative !
Its about time someone tries this. Spring is coming soon and Ive been looking for a CRX with the same intent. I plan to stay with the 1.6 liter though, and stay under 250whp for fuel economy.
Most use E85 for high boost, but I want to use lots of compression and low boost for fuel efficiency and mild power.
I have everything in my garage to build a 13.5:1 turbo b20/vtec, but there is one thing holding me back the fact that I seem to have misplaced my *****.
LMAO. rock on. spool is gonna be fn quick. with a 50trim, that'll be about 450 with the compression i'm guessing. can't wait to see the outcome.
