IAC IAT problems?
Old Mar 12, 2010 | 10:51 AM
98gsr-808-91dx's Avatar
Default IAC IAT problems?
got my y7 running but now thowing codes for iac and iat. took off my iac and cleaned it and still throwing the code. o and also surging. but my friend said wen he did this swap he had to run the iat wires directly to the wires off the ecu? is this true? any ideas?
Old Mar 22, 2010 | 07:01 AM
elizabeths dad's Avatar
Default Re: IAC IAT problems?
ok i have a 97 honda civic ex we just replaced the motor it has a 2000 d16y7 on the harness i had it was a 3 pin iac so we had to cut and put a 2 pin plug i found on here were it said disregard the orange wire . ok so ihooked the blue and black wire and the yellow and black wire and thats in and its not pickin up the iac any advice?
Old Mar 22, 2010 | 07:20 AM
4g4dcruisin's Avatar
TO THE OP
-What ecu are you running?
-Did you convert to obd2 properly?
-Are you running the y7 engine harness or the stock EF harness?
Anyways if your idle is surging when you plug in the IACV, then either your wiring is wrong, or your IACV is dead. The IAT code will only come on if its either broken or the wiring is wrong.
Old Mar 22, 2010 | 08:09 AM
a p06 its the y7 y8 swap harness
Old Mar 22, 2010 | 09:08 AM
4drEF's Avatar
Keyboard Humorist
holy freaking thread hijack
Old Mar 22, 2010 | 10:18 AM
start your own thread, i wasnt asking you a question.
efhondaracer27
Jun 1, 2010 02:44 AM
thesoundofturbo
Aug 18, 2007 09:10 PM
Max Kling
Aug 9, 2006 10:20 PM
VTcivicHB
Nov 11, 2005 05:08 PM
0 0 0
Feb 7, 2005 12:20 PM
