what size is the washer from 5th Gen fuel filter
Old Mar 12, 2010 | 09:51 AM
silent1jt's Avatar
Default what size is the washer from 5th Gen fuel filter
i recently had a mechanic change my fuel filter because i couldnt take off the bottom bolt. now im leaking gasoline from the top hose of the filter, i know there should be a washer in there and i dont believe it was put in. i need to know the size of that washer so i can go to autozone and replace that myself since that 1 isnt that difficult. i tried asking at autozone but they dont know what size it would be. this is for a 94 accord ex sedan
thanks alot
Old Mar 12, 2010 | 11:46 AM
redbull-1's Avatar
Default Re: what size is the washer from 5th Gen fuel filter
They should be 12mm sealing washers. You will need 2 washers for the top.
Old Mar 12, 2010 | 12:59 PM
silent1jt's Avatar
thanks.....hmmm....i looked at it closely a while ago and i actually saw the leak comming from the actual hose from the inside. as if the hose is not tight enough around the fitting. im going to try to tighten it down a bit more.
Old Mar 24, 2010 | 03:13 PM
silent1jt's Avatar
does any1 know what the # 3 part on the diagram is called? is it just a fuel line or is it another name? this is what is actually busted n im going junk yard searching for it.
EscoSi
Aug 13, 2013 09:10 AM
kbouchard1092
Aug 18, 2007 04:22 AM
authentic plusONErandy
Jul 28, 2005 12:35 AM
dustin
Aug 4, 2004 12:40 PM
NeXtLeVeL_TyPe_R
Apr 6, 2003 01:39 PM
