HELP QUICK PLEASE!!!
Old Mar 12, 2010 | 06:47 AM
alx_90ef's Avatar
Default HELP QUICK PLEASE!!!
ok so ima go to the junk yard right now and get an LS engine..
what else do i have to get ohter than,
ecu harnnes injectors etc.
and other than the mounts too..
like reat t bracket?
or whats that bracket that goes from the rear mount to the tranny?
half shaft?
axels???
i got a tranny btw.
let me know if i missed something
thanksss
Old Mar 12, 2010 | 06:49 AM
1990hondacrx's Avatar
Default Re: HELP QUICK PLEASE!!!
rear t bracket mounts u will have to have hasports or something engine harness u dont need need you can use the one thats on your car which is a good idea the ecu axels, half shaft,
Old Mar 12, 2010 | 06:54 AM
alx_90ef's Avatar
wait do i get the rear bracket from a DA?
Old Mar 12, 2010 | 06:59 AM
yes a da teg is what u want nothing newer the other ones are to big
Old Mar 12, 2010 | 07:03 AM
you also need the throttle cable from the da
Old Mar 12, 2010 | 07:05 AM
alx_90ef's Avatar
even tho my car is an si?
Old Mar 12, 2010 | 07:06 AM
lunalink's Avatar
dont forget the linkage of a DA also!
you can use the crx hf or si cable but you will have to make a custom bracket on the intake manifold so it fits correctly thats why i did but other wise if you dont want to make a bracket and fool with it get the throttle cable
Old Mar 12, 2010 | 07:09 AM
throttle cable
linkage
ecu
engine "of course"
rear T Bracket
Mounts Hasport or ebays
Beat frame rail on drivers side in
beat the back cross member in where the rear motor mount goes so your rear mount doesn't hit it
axels
halfshaft
Old Mar 12, 2010 | 07:22 AM
alx_90ef's Avatar
thanks man i appreciate it!!
i'll let you know what i get
TypeRfit
Feb 26, 2012 06:54 PM
Crank
Nov 7, 2008 02:30 PM
ALL IMPORT
Mar 8, 2006 08:12 PM
b16clutch
Dec 28, 2005 09:55 AM
