New block from Blueprint Racing!
Old Mar 12, 2010 | 05:56 AM
11sec CR-X's Avatar
Default New block from Blueprint Racing!
Just wanted to say thanks to my boys Ben and Robert at Blueprint Racing for the new block! Car is gonna love it! :up: Just wanted to share some pics! Thanks guys!
Old Mar 12, 2010 | 05:58 AM
88Hatchy's Avatar
Default Re: New block from Blueprint Racing!
Are those holes in the piston tops gas ports of some kind?
Old Mar 12, 2010 | 05:59 AM
alterdcreations's Avatar
nice....where is the rest?
11sec CR-X's Avatar
Yeah vertical gasports!
rest of what? My build?
Old Mar 12, 2010 | 06:21 AM
BLK2DOOR's Avatar
Nice short block.
Old Mar 12, 2010 | 06:23 AM
11sec CR-X's Avatar
Originally Posted by PirateMcFred
looks pretty.
Pretty high compression given it's a K24. I'm assuming this is race only, or are you going to run E85?
Yes a K24 block race only going in a procar get some shake down runs and seat time. Then bump up to a stroker from Blueprint!
Originally Posted by BLK2DOOR
Nice short block.
Thanks
Old Mar 12, 2010 | 06:26 AM
4piston's Avatar
Looks good Chris. Congrats.
Old Mar 12, 2010 | 08:33 AM
11sec CR-X's Avatar
Thanks hope my next package is from YOU!
Old Mar 12, 2010 | 10:18 AM
88Hatchy's Avatar
I've never seen this before. What are the advantages? Are the vertical ports for race use only¿
Old Mar 12, 2010 | 10:36 AM
11sec CR-X's Avatar
Yeah for dragracing. Here is wisecos explanation: Vertical gas ports are primarily used in drag race applications. Lateral gas ports are more often used in circle-track and road-race applications where carbon build up can occur. When gas ports are used, pressure is directed to build up behind the compression ring and seal it against the cylinder wall. This helps prevent ring flutter and extends the power curve upward in the RPM range. Vertical gas ports have the holes drilled from the deck of the piston into the top ring groove and behind the ring. Lateral gas ports are drilled through the bottom side of the top land and extend to the back wall of the ring groove.
Old Mar 18, 2010 | 09:47 AM
JPM98EK's Avatar
Very nice bottom end. whos doin the head work?
Old Mar 18, 2010 | 10:28 AM
11sec CR-X's Avatar
Team4Piston (4Piston a few posts up)
Old Mar 18, 2010 | 10:43 AM
dudesitsjdm's Avatar
block is so pretty id frame it and put on my fireplace any day
Fit_spoon
Honda Fit
16
Sep 21, 2008 01:33 PM
cigrafix2
May 3, 2008 06:51 AM
cvp467
Sep 15, 2005 06:30 PM
turbochic
Nov 18, 2004 09:16 AM
t o m
Nov 22, 2003 02:34 PM
