Oil Pan Problems Need help ASAP
Old Mar 12, 2010 | 05:02 AM
zoso's Avatar
Default Oil Pan Problems Need help ASAP
Hello everyone, so i have a 2000 civic ex stock with a d16y8. I was changing my oil today and noticed that the treads in my oil pan are stripped and causing the oil to drip out when the plug is in(very slow tho). My question is i think i have a few ways to fix this. I can change out the oil pan for a new one. If i do this how hard is it for me to do by myself? Anyone know of a DIY on this? I also hear you can rethread the hole. If so how hard is this to do and what size would i need to rethread it with. Thanks for all the help!
Old Mar 12, 2010 | 05:11 AM
Duhul's Avatar
Default Re: Oil Pan Problems Need help ASAP
I've got the same problem with my 92 eg hatch. I read that you can put teflon on the plug, but I'm not sure if that's the best. Would be the cheapest.
Old Mar 12, 2010 | 06:03 AM
zoso's Avatar
thanks for the suggestion
Old Mar 12, 2010 | 06:40 AM
97twodoor's Avatar
Teflon would be a temporary fix, as every time you change your oil the threads will get more and more damaged. So there are two options,
1: Get a new oil pan and install it. Pretty straight forward installation. You remove the exhaust from underneath the pan, the transmission support bracket underneath, the little splash shield covering the flex plate or flywheel (depending on whether it's a 5 speed or automatic), then the oil pan itself.
2. Remove the oil pan and drill and re-tap the threads to accept a larger bolt size. I say remove the pan because you don't want to run the risk of getting metal shavings inside the pan while it's still on the vehicle. After you re-thread the pan, then give it a good wash to get out any shavings or sludge that may be in there. Installation is reverse the removal procedure.
Old Mar 12, 2010 | 08:26 AM
zoso's Avatar
Sounds good. How hard is it to take off the oil pan, 1 being changing your oil 10 being engine swap. I have a 200 piece basic tool set, jack and jack stands. Will i need more than that?
Old Mar 12, 2010 | 08:43 AM
zoso's Avatar
Will a d16y5 oil pan fit on mine? im guessing it will, the only difference if the intake many on it and that wont effect it, am i right?
Old Mar 12, 2010 | 09:02 AM
97twodoor's Avatar
Yes, it should fit. And on a scale of 1-10, probably a 2. It's simple wrench turning. A jack and stands should be good for you to get underneath.
Old Mar 12, 2010 | 09:59 AM
zoso's Avatar
Ya i thought it was a pretty easy job to do. Do you know DIYs on it or is it pretty straight forward. Just take off down pipe, tranny mount(how many are there just 1?) and unbolt the oil pan, swap out and repeat? Do i need anything else, like a seal or anything? Thanks for all the help man...
Old Mar 12, 2010 | 10:54 AM
shwanC's Avatar
The hardest part will be breaking the exhaust manifold bolts. Heat and rust, not a good combination. A good amount of Pb Blaster will help. It may be easier to just remove the entire manifold, instead of breaking it apart.
You will need to get a decent brand oil pan gasket, and I would suggest a new plug as well. DO NOT OVER TIGHTEN THE PAN BOLTS. They don't require much torque; a nice, quick call to a Dealer could be made for the requirements.
Old Mar 12, 2010 | 01:04 PM
97twodoor's Avatar
The best DIY is probably in a Haynes manual. Do you have one?
Old Mar 12, 2010 | 01:18 PM
zoso's Avatar
no is there any online type haynes?
Old Mar 12, 2010 | 01:21 PM
97twodoor's Avatar
Other than AllData or Mitchell (paid) then no, not that i know of.
cyn7
Honda Civic (2001 - 2005)
Nov 28, 2011 09:13 PM
z4nd
27
Oct 2, 2010 09:39 PM
modernmav
Mar 22, 2010 11:18 AM
92preludeSI
Mar 10, 2003 07:33 PM
