Clutch Dead?
Old Mar 11, 2010 | 10:08 PM
ChenLung's Avatar
Default Clutch Dead?
My clutch pedal sticks when its in which i can pull out with my foot. it doesnt seem to have any pressure until its nearly completey at the bottom and then it catches right away. sometimes i cant even shift until ive pumped the pedal a lot. wuddup with that?
Old Mar 11, 2010 | 10:20 PM
ChenLung's Avatar
Default Re: Clutch Dead?
help
Old Mar 12, 2010 | 04:06 AM
xide_12's Avatar
Sounds like you need to bleed your clutch line, if its hydraulic
Old Mar 12, 2010 | 04:09 AM
96hb's Avatar
Check your master and slave cylinders to see if there's a leak. I had the same problem with my car last year and it ended up being the slave. It was an easy fix. If both of those seem to be ok, try bleeding the line and putting in fresh fluid. I would be willing to bet that it is the slave cylinder though. Good luck!
b20vteg757
Jun 26, 2015 01:35 PM
ducsaim
Jan 14, 2011 12:17 AM
JDMfan77
Jul 12, 2010 08:54 PM
josejdm
Oct 7, 2009 02:22 PM
stock95civic
Mar 12, 2007 10:55 PM
