Leaking fluid??
I started my car today and its been in my garage over the winter but its been nice last couple days, so after its all warm i look under car and theres a drip every 6-8 seconds coming from front left part of car by tire, i smelt it & it smells like gas i put a bucket underneath and collected some and it was clear.. plz help
the only things that are up front and to the left is your power steering reservoir and water sprayer reservoir, one gas line runs on the left side to the rail where the fpr is but it isnt up front near the tire
hey could u decrive to me where to look as to where the leaking is comming from, i was fiddling around behind intake mani because i had to re tighten my fitv so could i possibly have knocked 1 of the lines loose??
i found the leak close to brake resevoir down abit theres a 17mm bolt and i felt underneath it and its definetly where its coming from, so sould i try tightening the bolt
they used teflon tape to seal around that 17mm, the bolts not loose so im assuming its comming from the tape, can gas be able to corrode the tape??
coming from the fuel filter, that hose and the fitting as you can see are pretty worn out and i believe its sweating a tiny bit of gasoline, before my leak was at the bolt on top of fuel filter, but now is hose where the metal meet the hose, where the fitting ends,
its a fuel line...get that replaced and make sure u get the same type of washer otherwise its going to leak again. or use the washers u have on it now...i was having that problem when i replaced my fuel filter.
My_GsR_eK
Sep 11, 2010 07:30 AM
