b16a3 into a 97 ek coupe pls help
Old Mar 11, 2010 | 05:31 PM
gsrboost737's Avatar
Default b16a3 into a 97 ek coupe pls help
ok guys can u please tell me wat parts i will need i am gettin the a wrecked delsol vtec harness axels ecu and motor and tranny shifter linkage are there wat other parts will i need
Old Mar 11, 2010 | 06:43 PM
Fresh'86's Avatar
Default Re: b16a3 into a 97 ek coupe pls help
Can I buy your a/c bracket from the del sol?
Old Mar 11, 2010 | 06:45 PM
Fresh'86's Avatar
You should also grab the header
98civdx's Avatar
Master Detailer
you cant use del sol linkage.
mounts
Old Mar 11, 2010 | 06:58 PM
iamthefollower's Avatar
can't use the harness either. the 94 and 95 Del Sol Vtec's came with the b16a3 and 96 and 97 Del Sol's came with a b16a2, if i'm not mistaken. But you could use the motor, tranny, axles, and intermediate shaft and also the ecu if you get an obd2a to obd1 ecu harness.
as 98civdx stated, you can't use the linkage from the Sol, the linkages will be about 4 inches too long for the Civic.
Just to make sure what year Del Sol are you getting? Anytime i've looked at the Del Sol Vtec's they were as I stated on the engines.
rstewart4328
Feb 10, 2015 05:54 PM
jdm.coupe3234
Nov 23, 2009 08:31 PM
riptegk20
Sep 16, 2005 06:52 PM
ubercerealkiller
Mar 30, 2005 03:45 AM
89JDMcrx
May 22, 2004 11:16 PM
