What is the biggest cam I can run b16
Old Mar 11, 2010 | 05:17 PM
EM1 Resto's Avatar
Default What is the biggest cam I can run b16
What is the biggest cam I can run on a B16a2 (stock internals)? Idle factor doesn't matter. Will Toda stage 3 work or too little PtV?
Old Mar 11, 2010 | 05:21 PM
BrandonR's Avatar
Default Re: What is the biggest cam I can run b16
I'm pretty sure TODA VTEC KILLER cams have the longest duration and largest lift. But why are you wanting to run a huge cam with stock internals?
Old Mar 11, 2010 | 05:38 PM
EM1 Resto's Avatar
It's just a weekend car I want to beat on and I love hearing a big cam idle.
Old Mar 11, 2010 | 05:44 PM
Deetz's Avatar
Crazy Honda Guy
Stage III cams on a stock engine = waste, you don't have the compression for them. Same goes for stage II cams like Toda or Skunk2, they are designed to operate well with compression 0f 11.5:1 and higher
Stage I cams are made for stock or mild engines
Old Mar 11, 2010 | 06:06 PM
Hondatherdm's Avatar
Originally Posted by Deetz
Stage III cams on a stock engine = waste, you don't have the compression for them. Same goes for stage II cams like Toda or Skunk2, they are designed to operate waell with compression 0f 11.5:1 and higher
really? thats good to know
Old Mar 11, 2010 | 06:22 PM
Laz's EP's Avatar
So He needs to find out what cams work the best for stock internals. Skunk2's or CTR's?
Old Mar 11, 2010 | 06:25 PM
toofresh1993's Avatar
deetz true just put gsr or type r thats the safest i think
Old Mar 11, 2010 | 07:44 PM
Schister66's Avatar
Man U FTW
ITR is the biggest cam you should use. Running some ungodly lumpy, aggressive cam would be a total waste of time and money. You can't just slap in a set of big cams and expect miracles. The rest of the setup must compliment your choice
Old Mar 11, 2010 | 09:03 PM
-__-'s Avatar
yeah i wouldnt put anything bigger than ITR/CTR cams on stock valvetrain. anything bigger is just asking for something to go wrong. also a waste of money if you can't REV them high enough to make the POWER out of them.
Old Mar 12, 2010 | 07:57 AM
fungus mungus's Avatar
^X2
Anything stage 2 or higher will mushroom your valves if you don't have an upgraded valve train. Trust me, I know from first hand experience...the person that had the motor swap I have now had been running stage 2 cams w/o an upgraded valve train. When I went to put in the motor, I checked the head over and this mistake ended up costing me some $$ for a whole new valve train. :/
fm
Old Mar 12, 2010 | 08:10 AM
EM1 Resto's Avatar
Originally Posted by fungus mungus
^X2
fm
That is the answer I am looking for. I could care less about the power.
NBPdEeCeE
Feb 2, 2007 05:14 AM
rdwaldo
Jan 30, 2007 07:24 PM
jdmitrna
26
Dec 14, 2006 07:34 AM
PearlCrx
Mar 5, 2004 12:51 PM
Stock-DC2
May 2, 2002 12:16 PM
