Tranny fluid change....what size hose?
Old Sep 8, 2002 | 12:03 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Tranny fluid change....what size hose?
What size and length hose do I need to refill my tranny fluid? I don't want to go out and buy a hose thats too big. Thanks.
Old Sep 8, 2002 | 12:04 PM
B2FiNiTY's Avatar
Default Re: Tranny fluid change....what size hose? (ActiveAero Ninja Edition)
Why would you need a hose?
Old Sep 8, 2002 | 12:06 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Tranny fluid change....what size hose? (B2FiNiTY)
It's in a pretty wierd position. Looks like I'm going to have to run a hose out to a funnel. Is there some other way to do it?
Old Sep 8, 2002 | 12:11 PM
Mugen Mike's Avatar
They make funnels with extra long hoses.
I picked one up at a local auto parts store for like $2.00
Old Sep 8, 2002 | 12:59 PM
R_yd's Avatar
Default Re: Tranny fluid change....what size hose? (mugenmike)
yup, just check w/ your local autozone and they'll have it
[Modified by Rspool, 10:15 PM 9/8/2002]
Old Sep 8, 2002 | 01:24 PM
sackdz's Avatar
Default Re: Tranny fluid change....what size hose? (Rspool)
bout 1/2" OD no bigger. fluid takes forever to go down though.
Old Sep 8, 2002 | 01:56 PM
kkim's Avatar
I just filled from the vent tube on the top of the trans. there's a black rubber cap on it that you can access from the engine bay.
Old Sep 8, 2002 | 02:14 PM
sackdz's Avatar
Default Re: Tranny fluid change....what size hose? (kkim)
How many days did it take? That hole is real small.
[Modified by sackdz, 6:15 PM 9/8/2002]
Old Sep 8, 2002 | 02:31 PM
kkim's Avatar
Default Re: Tranny fluid change....what size hose? (sackdz)
wasn't that bad. find some tubing that will fit over the vent tube and not into. went fine for me.
Old Sep 8, 2002 | 02:35 PM
Racebrewer's Avatar
I just changed my tranny fluid two hours ago. I used the $1.99 funnel with a hose and a 3 inch long piece of clear vinyl tubing (3/8ths ID) from the end of the funnel hose to the vent tube.
When I drained the fluid I removed both the drain plug and the 'filler' plug. After drining I put the drain plug back in and then put in the first 2 quarts through the vent tube. It went in fairly fast. I then put the filler plug back in and added the last .3 quart. That went in pretty slow. I did it that way because the car was jacked up at an angle and I wanted to get a complete fill.
Good luck
John
Old Sep 8, 2002 | 02:47 PM
Bbasso's Avatar
find a small hose, one thatv fits inside the funnel :
Old Sep 18, 2002 | 10:33 PM
accord-euro-r's Avatar
New User
I just changed mine with a funnel and a PVC hose from HomeDepot like 1.50
Sz is like 1/4"
Just look at yr bolt and measure. Real easy!
Old Sep 19, 2002 | 05:23 AM
AssPenny's Avatar
Default Re: Tranny fluid change....what size hose? (accord-euro-r)
Get a pump from autozone, makes it 10x easier
Craig - Who changes his tranny fluid every 6k miles
Old Sep 19, 2002 | 05:43 AM
Willard's Avatar
Default Re: Tranny fluid change....what size hose? (AssPenny)
why do you wait so long?
Old Sep 19, 2002 | 10:31 AM
Hooch'n's Avatar
Default Re: Tranny fluid change....what size hose? (C5_ALLMOTOR)
Andy: Who needs to change his soon.............
Thanks for the reminder
Old Sep 19, 2002 | 10:33 AM
-Whitey-'s Avatar
Default Re: Tranny fluid change....what size hose? (Hooch at 8400-RPM)
i just use about 6inches of hose attached to a small funnel and then i use a bigger funnel to fill her up
its not the fastest way but i never spill
Old Sep 19, 2002 | 10:51 AM
Bbasso's Avatar
Default Re: Tranny fluid change....what size hose? (one_honda)
this:
Dr.Fixit
Oct 24, 2013 06:22 PM
ludewithanh22
Feb 6, 2005 12:50 PM
cueballsi
Nov 2, 2004 11:52 PM
Floyd
May 9, 2002 10:58 AM
stRtypR25
Jan 20, 2002 08:21 AM
