Suspension & Brakes Theory, alignment, spring rates....
Spherical bushings kit?
Old Mar 11, 2010 | 02:17 PM
PARADOX_sf's Avatar
Default Spherical bushings kit?
Hello.
Is there anybody who are using them? Are they ok for daily use?
I installed full set of spherical bushing on my civic EG but i am hesitating about front and rear lower shock bushings. Is it a good idea to leave them with stock rubber bushings to make the car a little softer on the high speed bumps or this won't affect the harshness?
Old Mar 11, 2010 | 09:28 PM
eklum's Avatar
Default Re: Spherical bushings kit?
i think they would suck to have for dd but most of our setups do any ways might as well go all the way.
Old Mar 11, 2010 | 11:22 PM
PARADOX_sf's Avatar
I've been using full polyurethane kit and the car was very harsh on the high speed bumps.
Old Mar 12, 2010 | 05:36 AM
phunhaus's Avatar
The spherical will be harsher than the polyurethane bushings. At this point in your bushing replacement why bother stopping with those four?
Old Mar 12, 2010 | 09:16 AM
eklum's Avatar
i was saying a sepherical bushing kit will be a very harsh ride and in my opinon overkill for a daily driving platform , but most guys setups on this forum are very harsh so you might as well just go for it if you want them.
Old Mar 12, 2010 | 12:41 PM
PARADOX_sf's Avatar
Hi.
I've been running with full poly bushning kit but the car became very noisy and harsher than the rubber bushings with stock eg6 shocks especially on high speed bumps. Shock's top and bottom poly mounts are very stiff. May be the thin tyres helped a lot. They are 205/40/17.
If i am using softer shocks or shocks designed to work with stiffer bushings i don't think that it will be harsh. If there is no shock i don't think that the car will be harsh, because there won't be anything to block free suspension movement.
I allready have coilovers with spherical top mounts.
Old Mar 12, 2010 | 01:16 PM
phunhaus's Avatar
If it came down to it, I would run rubber bushings and stiffer springs/dampers rather than spherical bearings and softer springs/dampers. If this is a street car there's going to be much less cost and maintenance with a hard rubber bushing set over a spherical set if you're not looking to overhaul or inspect the car annually.
Old Mar 19, 2010 | 12:03 AM
zel05's Avatar
When I ordered replacement spherical bushings for my Eg Civic, it was recommended that the shock mount bushes retain the oem / hard rubber bushes.
I bought my sphericals through Kiwi at Special Projects Motorsport. I still have the installation instructions that went into a bit more detail...I'll have a look for it next time I get a chance.
Old Mar 19, 2010 | 08:51 AM
PARADOX_sf's Avatar
Hi.
My sphericals arrived without instructions. Could you make me a photo of them?
Thank you!
jdmem205
Nov 12, 2013 02:35 PM
CoastalSi
Jun 5, 2010 10:30 AM
blulude92
May 22, 2006 10:58 PM
fastbrakes
Nov 21, 2001 06:32 AM
