Suspension & Brakes Theory, alignment, spring rates....
Brake Difference ??
Old Mar 11, 2010 | 09:18 AM
jksmith's Avatar
Default Brake Difference ??
I have searched every way i can imagine, and cant find the answers to my questions!
1. What is the difference in front brakes between a 95 EX and a 99 SI? (i know rotors are the same)
2. What is the difference in rear brakes between a 99 SI and a DC (gsr or ls) (i know rotors are the same)
Old Mar 11, 2010 | 05:12 PM
roastbeefrichie's Avatar
Default Re: Brake Difference ??
they're also known as "the non-DX knuckle"
(the DX knuckle found on 88-00 civic, uses smaller caliper w/ 9.5" front rotor)
...the 95 civic EX & 99 civic Si fall into the category of bigger knuckles/spindles:
90-00 civic EX
90-01 integra
del sol B16
99-00 civic Si
the front calipers are compatible & will swap back-and-forth
all use the same sized 10.3" front rotors
any 88-00 civic/crx/del sol with rear disc
or
90-01 integra LS/RS/GS/SE/GSR (excluding ITR)
uses a rear caliper stamped 7CLP13S
they share the same sized pads & 9.4" rear rotors
the part #'s might be different but will interchange
(trailing arms, calipers, brake hoses, pads & rotors)
* the rear LCA's do not mix...
EF EG DC (including ITR) rear LCA work together,
DA & EK must use rear LCA's within their gen
Old Mar 12, 2010 | 07:42 AM
jksmith's Avatar
only question i have now are the Front Calibers the same from a 95ex and 99si?
Old Mar 13, 2010 | 06:46 PM
SHotime2511's Avatar
Yes.
Old May 16, 2010 | 08:14 AM
VR6guy79's Avatar
Sorry to revive an old post, but I had a further question. I have a 94 Del Sol S with the 9.5" front rotors. From what I am reading I should be able to buy the larger 10.3" front rotors and a set of calipers/pads from a car with the larger rotor stock and call it a day. Is this correct? Or are there other parts that would be needed to upgrade the front brakes to this larger rotor?
*Edit: I am already planning to swap the proportioning valve/cylinder as part of the rear drum to disc conversion.
Thanks.
jksmith
Mar 12, 2010 07:42 AM
zerokool1128
Aug 14, 2008 08:53 PM
aquabob89
16
Jul 6, 2008 06:45 PM
ek4 coupe
Aug 29, 2004 03:10 PM
DX Hybridizer
Nov 18, 2003 06:12 PM
