new antenna install question
undo the screws on it at the top. unplug it and pull it out. slip in the new one. do up the screws and under the dash plug it in. (that is if its under the dash), mine was. then it goes to the back of the radio. some go directly to the radio.
Unplug the antenna, then unscrew it at the top. Pull the antenna out a little bit and cut it. Electrical tape your new antenna to the old one and pull the old one inside the car and it will feed your new one right thru.
97teg415
Audio / Security / Video
Sep 20, 2007 07:30 AM
