d16 or d15 block?????
Old Mar 10, 2010 | 07:15 PM
d15bef's Avatar
Default d16 or d15 block?????
i got a jdm d15b vtec head that i wanna put on but cant find the matching block. i got a d15b2 in the car and a d16y7 block in the garage. with higher compression pistons what block should i use? ive heard of alot of people using the d16 block.
Old Mar 11, 2010 | 08:08 AM
dr_latino999's Avatar
Default Re: d16 or d15 block?????
Depends on the pistons, since you have to factor in if they will only work with D15 length rods or the D16 length rods
Old Mar 11, 2010 | 07:56 PM
d15bef's Avatar
im thinking i wanna use d15 with higher compression pistons but just wanna make sure its better than the d16
Old Mar 11, 2010 | 08:49 PM
prelude182's Avatar
use d16 rods if your using the block. depending on the pistons a high compression will give you a little bit of boost in power.
B*Goods*EJ2
Dec 4, 2009 07:34 AM
turboblack2door
Nov 30, 2008 11:06 PM
civicjoe
Apr 7, 2008 11:04 AM
