Help with my vitara build!
Old Nov 29, 2008 | 03:10 PM
turboblack2door's Avatar
Default Help with my vitara build!
so i'm wanting to do my vitara build with a d16a6 block with custom eagle rods to d15 length. But in doing this i will lower the compression significantly. So to resolve this issue and take the compression to where i would like i was thinking about milling the block to 205mm. D16a6 block stock is 212mm and the d15b2 block is 207mm. Does anyone see a problem with milling 7mm of the top of the d16a6 block which will make it 2mm shorter than the d15b2 block?
Old Nov 29, 2008 | 06:24 PM
CoreyR's Avatar
what exactly would be the point? why not just use the correct rods for the block? milling over 1/4" off the block cant possibly be a good idea.
Old Nov 29, 2008 | 10:11 PM
viskii420's Avatar
x2
Old Nov 30, 2008 | 09:32 AM
the point would be to keep a d15 length rod for strength over a d16 rod (both eagle h beams) and since using a shorter rod and vitara pistons you will have a way low compression so if you mill the block down on the d16 7mm it will bring the compression up to 9.33:1 thats why. If you think about it it will take the d16 block down to 205mm which is only 2mm shorter than the d15 block
Old Nov 30, 2008 | 04:13 PM
dez6's Avatar
You know FJT distributors makes d15/d16 rods specifically for the vitara setup so deck height wouldnt be an issue.
Old Nov 30, 2008 | 04:38 PM
d15's have smaller bearing journals
Old Nov 30, 2008 | 11:06 PM
CoreyR's Avatar
youll never make enough power with a d series to break an H beam rod due to power.
K20teggg95
Nov 4, 2011 06:44 AM
d15bef
Mar 11, 2010 08:49 PM
TomTread
Apr 21, 2008 01:35 PM
civicjoe
Apr 7, 2008 11:04 AM
