Fuel Rail leak!! =(
Old Mar 10, 2010 | 06:47 PM
ekHatchdom0's Avatar
Default Fuel Rail leak!! =(
ok so i had a leak in the top of injector 2 change the o ring with an extra i had
then the leak went to injector 1 i tried changing o ring on it but the one i put on wasnt the greatest; do u think its just the o ring need to replace??? lmk plz any input
Old Mar 10, 2010 | 07:11 PM
njmad's Avatar
Default Re: Fuel Rail leak!! =(
YEAH. what else could it be?
Old Mar 11, 2010 | 07:06 AM
idk wasnt sure. im get new o ring today and see if it works
Old Mar 11, 2010 | 07:24 AM
RCurioso88's Avatar
had the same problem when I installed my AEM fuel rail and got the car tuned. The O-rings tore in injector 3, I replaced it. Then 10 mins. later, the o-ring in injector 2 tore and I got sick of it. I replaced the injectors from an integra at work ( i work at a junkyard) and put on my stock fuel rail. No problems since.
BTW, if you plan on doing this, make sure you oil up the part of the injectors that go onto the fuel rail AND to clean the injectors while they're out. I used fuel-injector cleaner, a towel, cleaned the gunk and soaked the injector in it for a good half hour. Now they work wonders lol. Good luck with it
blu3fan
Nov 16, 2012 05:05 PM
mw011i
Jul 18, 2008 05:06 AM
ThePro
Jun 16, 2005 08:58 PM
b00sted4dr
Feb 7, 2005 10:50 AM
Cowboy
Mar 18, 2004 05:56 PM
