EG6 Fog Light Problem/Situation.
Old Mar 10, 2010 | 06:09 PM
LSR_jr.209's Avatar
Icon2 EG6 Fog Light Problem/Situation.
I have a "EG6" and recently installed the $30.00(-/+) ebay so-called Jdm Fog light kit. Lights turn on when park/drive lights are on. I have original Grey switch for JDM EG6 & works fine. Everything works fine...
EXCEPT
when I put on the front bumper and the Fog light mounts touch the EG6 chasis, the 30watt fuse blows out. I tried rewiring the entire kit AGAIN, and still the same result. The fuse blows. I double/triple checked the fuse terminal under the dash, and tried upping/lowering fuse wattage. Sucks to be me, but any suggestion that can fix my Fog light situation? or other options installing my Fog lights?
Old Mar 10, 2010 | 06:13 PM
_eg6_'s Avatar
Default Re: EG6 Fog Light Problem/Situation.
buddy had same problem...the actual fog light casing was positively charged check yours and could possibly be the same problem...he just put some innner tube from a bike tire on the frame and solved the problem
Old Mar 10, 2010 | 06:19 PM
jdmcivic1's Avatar
Could be a ground issue.
this is where i got my from:
http://www.jdmrides.ca/forum/d-i-y-d...ght=fog+lights
BTW. Those ebay foglights are cheap. I might the quality. I already brought 2 pairs. For some reason the blubs would go out on them. Hope it doesn't happen to you after you get this issue fix.
Old Mar 10, 2010 | 06:20 PM
LSR_jr.209's Avatar
You mean covering the Fog light casing? or covering the mounts touching the chasis?
Thats going to suck a ton for me if that happens.....
The-Kid
Dec 19, 2016 11:38 AM
Neticz
Oct 24, 2015 12:18 PM
immajackuup
May 7, 2010 01:00 PM
Spawne32
Apr 2, 2010 07:25 PM
Lil. Cease
Mar 4, 2007 05:35 PM
