Suspension & Brakes Theory, alignment, spring rates....
what gc springs to get for my koni yellows
Old Mar 10, 2010 | 06:05 PM
chrisff521's Avatar
Default what gc springs to get for my koni yellows
I have koni yellows right now sk2 springs and the springs are **** with the konis. So now I'm upgrading to gc coiolver sleeves. My question is wat spring rate do I get ? And wher can i get them cheapest. ?
Old Mar 10, 2010 | 08:52 PM
chrisff521's Avatar
Default Re: what gc sleeves to get for my koni yellows
Help.....
Old Mar 10, 2010 | 08:56 PM
kaiba's Avatar
What is the car going to be used for? Visit http://www.ground-control-store.com/
Old Mar 10, 2010 | 08:58 PM
stevieteg's Avatar
Unless you plan on tracking the car I'd just get the standard rates for your car with the Koni specific GC sleeves.
Old Mar 10, 2010 | 09:19 PM
chrisff521's Avatar
its a daily driver with bumpy *** roads lol
Old Mar 10, 2010 | 10:23 PM
chrisff521's Avatar
Someone help me please. I want to get theses tomorrow. On their website they have a few. They have show, swap, and road race. Which should I get.
Old Mar 11, 2010 | 05:10 AM
96hb's Avatar
Just call them up and tell them what your plans are for the car. They will help you choose the appropriate rates. They will probably advise you to get the standard kit for a daily driver. That's what I have and it is fine. As for sleeves, there is only one choice there. You have to get the sleeves that are designed specifically for the Koni shocks. Good luck!
Old Mar 11, 2010 | 05:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Thread title edited - it was asking about sleeves but then you posted asking about springs.
I used to run 380 lb/in up front and 450 lb/in in the rear. It rode stiff as hell due to the higher rear spring rate.
If I had to do it again I would go with something like 400 lb/in up front and maybe as low as 250 lb/in in the rear. The 400's should allow you to lower a decent amount w/o hitting shock towers if you stay with OE upper control arms.
Old Mar 11, 2010 | 10:24 AM
kristo's Avatar
Loved
Default Re: what gc springs to get for my koni yellows
Are you on lowering springs or coilover sleeves?
If the latter is the case then you could of course get lower rate springs from Skunk2.
No real or practical quality difference, unless you are a perfectionist.
Originally Posted by Captain Janeway
Sometimes perfectionism stands in the way of efficiency
Old Mar 11, 2010 | 11:57 AM
chrisff521's Avatar
im on lowering springs. Is it possible also I could just get skunk2 coilovers? but would they fit on my koni shocks?
Old Mar 11, 2010 | 12:18 PM
STOCK_SOHC_DX's Avatar
Yes you can but you still need to order the Skunk2 mount rings for the Koni shocks, so you might as well get the GC Koni specific kit. I myself would go with custom rates, I was looking @ 430 fr 375 rr.
Old Mar 11, 2010 | 01:12 PM
Community Builder
GC sleeves made for Koni shocks fit without the need for spacers or adapter rings. Much cleaner setup IMHO.
Old Mar 21, 2010 | 06:06 PM
chrisff521's Avatar
its not that big of a deal. But how are skunk2 coilovers? Ride nice?
Old Mar 21, 2010 | 06:32 PM
kristo's Avatar
Loved
'Nice' is a subjective term.
Skunk2's 'adjustable coilovers' sport 450/335 springrates (which is not so diff from suggested rate above).
And you can always get other springs with other rates, and even mount GC extended top hats.
(do get the Skunk2 rings for Koni shocks like mentioned above)
Old Mar 21, 2010 | 06:44 PM
chrisff521's Avatar
do all skunk2 coilovers have a rate like that^^?
Old Mar 21, 2010 | 08:02 PM
92integraVTECgsr's Avatar
Just go to ebay, search Ground Control Coilovers for whatever car you have, and buy the ones that are made to work with Koni Yellow shocks. You don't need any custom rates. Just get the OTS (off the shelf) rates.
Old Mar 23, 2010 | 11:09 AM
civicjason's Avatar
what car is it for? Ill help you
Old Mar 23, 2010 | 11:26 AM
civicjason's Avatar
if its a 94+integra you got about 1210kg car with 64/36 distribution, motion ratio is about .7 i think. For a good ride quality i would suggest 375-400 up front and 225 rear but i wouldnt go over a 300 on back.
Old Mar 23, 2010 | 12:33 PM
chrisff521's Avatar
sdomebody is selling me ground control coilover sleeves with skkunk2 springs mounted on the sleeves instead of the ground control springs. Do you think this is a good buy?
Old Mar 23, 2010 | 06:22 PM
chrisff521's Avatar
Old Mar 24, 2010 | 07:34 AM
chrisff521's Avatar
Is it a good setup?
Old Mar 24, 2010 | 09:12 AM
Community Builder
depends on the spring rate, hard to say if it's a good buy without knowing that. Just make sure they're the proper 2.5" ID springs to fit on the GC sleeves.
Old Mar 24, 2010 | 12:44 PM
chrisff521's Avatar
on their site it say that the front is 10kg/mm and the rear is 8kg/mm as the spring rate. How does that convert to lbs total for the front and rear?
Old Mar 24, 2010 | 12:45 PM
chrisff521's Avatar
i think you have to multiply by 55 or something and I got a front spring rate of 550
and rear of 440? Is that right
Old Mar 24, 2010 | 01:21 PM
kristo's Avatar
Loved
Try editing your posts instead of posting multiple ones in a row.
Skunk2 springs typically come with a number on them like 0500.250.006, which means:
5" length, 2.5" inner diameter, 6kg/mm.
6kg/mm = 60kg/cm = 337lb/inch
So 1kg/mm = 10kg/cm = 56lb/inch
808dc2typer
Suspension & Brakes
10
Sep 4, 2015 05:05 AM
egb18c5
Suspension & Brakes
Dec 26, 2006 06:14 AM
DLudist
Suspension & Brakes
Jan 14, 2006 11:19 AM
Myh4tch
21
Jan 20, 2004 04:15 AM
paRRRker
Dec 3, 2002 07:27 AM
