Stock d16y7 bogging
Idles fine, sometimes a bit low in the RPM but not bad.
By bogging I mean a temporary loss of power.
Driving in any gear at any speed the engine will bog intermittently, if you let off the gas for a second and re apply the gas it will act normal for a few seconds and do it again. Same thing happens if I step on the throttle when it bogs, it will act normal for a few seconds and bog again. If you step in the clutch when it bogs it will idle normally.
It has a new fuel filter in. And no CEL.
I just drove 20 miles to school with it bogging and no CEL lit up.
What do you peeps think?
Thanks in advanced.
Thanks in advanced.
I had the same problem with my D16 bogging out when I first put the civic on the road a couple months ago. I replaced the spark plugs, spark wires, air filter and cleaned the TB and it solved the problem for me. Try cleaning the TB if its dirty and replace your filter, then try new plugs/wires.
ive cleaned my tb and iacv fuel injectors ive checked cap and rotors ive checked gap and changed spark plugs its getting spark new fuel filter fuel pump primes only cel codes is 1 and 65 which is 02 sensor because i have 4-2-1 header and havent gotten o2 extension. i really need help its my dd
Punker1234
36
Jan 27, 2006 01:50 PM
95ILS
Jun 21, 2005 09:13 PM
