**CLuster Not Workin where to STRT?**
Old Mar 10, 2010 | 12:23 PM
trevek10's Avatar
Default **CLuster Not Workin where to STRT?**
hey everyone... just give background
car is 99 civic cx
just swapped a b18c into it couple months back
running a 99 si harness with obd2 to obd1 coversion harness at ecu
dash harness is stock
everything in the car works fine minus the code for knock cause i broke it(nothing to do with it)
the car recently decided to not register the mileage on the cluster im stuck at 000000 and the miles 120000 not sure why or what could have caused it .. was driving one day and realized i wasn't racking up the miles on the car anymore / (everyhting else on cluster is perfect)
was wondering where i should start to diagnos the problem or what to do besides throw in a new cluster
anyone ever had a similar problem???
Old Mar 10, 2010 | 04:24 PM
trevek10's Avatar
Default Re: **CLuster Not Workin where to STRT?**
bump
Old Mar 10, 2010 | 05:44 PM
jdmcivic1's Avatar
I had the same problem:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/cluster-not-working-2579017/
It might not help but it's a start. VSS? Fuse? or Open the cluster and roll it over one mile then see if it wasn't stuck. Disconnect the battery?
Old Mar 13, 2010 | 03:13 PM
trevek10's Avatar
ill try some of those..
thanks
Old Mar 13, 2010 | 03:45 PM
1 sLoW hAtCh's Avatar
you need to replace the speedo unit, i'm sure thats the culprit.
Old Mar 13, 2010 | 03:59 PM
92civdx's Avatar
Same thing happened to mine. It was a 10 fuse under dash. I have a eg so I don't know if it is all the same D:
Old Mar 15, 2010 | 07:54 PM
trevek10's Avatar
thanks all!
dochazmat
Honda Civic (2001 - 2005)
Jan 22, 2016 01:08 PM
zpayne21
Jan 4, 2015 06:32 PM
weekendboost
Apr 8, 2013 08:38 PM
kaboomwoom
Mar 12, 2008 01:06 AM
fujiwara takumi
Jan 19, 2006 08:54 PM
