OBD2B NO C-PLUG ON ECU?
I HAVE A 1998 EK HATCH WITH A 2000 SI B16A2 SWAP. IM HOOKING UP THE ECU AND THERES NO 3RD PLUG COMING FROM THE DASH, SO IM JUST RUNNING 2 PLUGS, EVERYTHING WORKS AND RUNS FINE EXCEPT I HAVE NO TACH OR SPEEDO, ALL OTHER GAUGES AND DASH LIGHTS WORK, JUST THOSE 2 DONT. DOES THAT MEAN I HAVE AN ODD HARNESS OR WHAT? I JUST CANT FIND THAT 3RD PLUG ANYWHERE. ANY IDEAS?
http://www.boomslang.us/obd2to2.htm
I guess idk for sure what harness it has. It does have the 2000 si ecu and motor so I'm assuming the engine harness is the same. Does that conversion harness change my 2 plugs into 3? Like I said there is no 3rd harness coming from the dash. Sorry about the caps lol my work computers are always stuck on caps. So I switched to my phone. Thanks guys.
i do not have the original ecu, im in the us, as is the car, i think its a canada civic though. but yeah like i said im not running a third plug at all and the only things that arnt working are the tach and the speedo. everything else works that i know of. i also noticed theres no plugs going to thecharcoal canister or other emissions.
You're using a '99 - '00 engine harness with a '96 - '98 underdash harness. Replace the engine harness with a '96 - '98 5 speed EX harness and you'll fix your problems.
WOULD THAT EXPLAIN MY MISSING 3RD PLUG? I WANT TO BE DAMN SURE BEFORE ANYTHING MAJOR GETS PURCHASED. EVEN IF I REPLACE THE ENGINE HARNESS THAT DOESNT PUT A HARNESS UNDER MY DASH. HAS ANYONE ELSE DONE THIS SWAP OR KNOW OF A WRITE-UP? IV BEEN SEARCHING ALL DAY AND ALL I CAN FIND IS UNRELATED STUFF, THANKS
Sure would.
It does actually. Observe the pic below. '99 - '00 Civic engine harnesses don't have the "A" plug because its part of the underdash harness, whereas on '96 - '98 Civics its part of the engine harness. Basically the engine harness and underdash harness have to match. You could also use a '99 - '00 underdash harness and keep your current engine harness, but its more work. Oh, and you don't need to keep the caps lock on.
Quit with the caps.
You have a 98 hatch - get a 96-98 Ex 5-spd harness, like has been suggested. You don't have the under-dash harness that has the "A" connector because that's present in 99-00 Civics...which you don't have. So quit looking for it and get the correct harness.
Quit with the caps.
It's unlikely the person you are replying to will respond to you or care about this thread due to the age alone.
Also, the information was well covered and documented. There really was no good purpose for you to bump this 7 year old dead thread.
triple_s1x
Jun 20, 2009 12:52 PM
