antifreeze in my itr trans?
Old Mar 10, 2010 | 07:58 AM
My_GsR_eK's Avatar
Default antifreeze in my itr trans?
It started makin a noise outa no where. Thought it was the throw out bearing so we replaced it but the noise is still there. I checked the trans fluid to see if it was low but Wen I took out the screw to check antifreeze nd like watery oil came out. How did antifreeze get in? N how do i fix da problem
Old Mar 10, 2010 | 08:02 AM
talkerty's Avatar
Default Re: antifreeze in my itr trans?
Do you have transmission cooler lines in the radiator?
Old Mar 10, 2010 | 08:04 AM
tlarimer's Avatar
Could have leaked in through the VSS hole. Have you done any work to the cooling system where you let coolant run down the transmission case?
Old Mar 10, 2010 | 09:30 AM
My_GsR_eK's Avatar
I dnt have any lines runnin to the trans
Old Mar 10, 2010 | 09:54 AM
namewasdallas's Avatar
did u just buy the car cause maybe someone was stupid and filled it with anitfreeze lol
Old Mar 10, 2010 | 10:25 AM
sohc eg's Avatar
wait...what?
1. If it's not an automatix transmission or a manual cable transmission, coolant will not be in the transmission unless you put it there. Whirring noise is probably the input shaft bearing, it's a very common problem with older honda transmissions.
2. Are you saying you drained the coolant and there was oil in it? Do a leak down test on your motor because you probably popped a headgasket.
NSelection
Aug 6, 2016 01:53 PM
tercelrcr
Jan 16, 2012 06:50 PM
-iLLuZioN-B18C1
Nov 4, 2004 05:29 PM
jaydeemmmm
Aug 23, 2004 08:02 AM
MasterSaif
Feb 15, 2004 06:19 PM
