leaking oil
so ive noticed im leaking a good amount of oil and when i look to see where its coming from its all over the top of the transmission housing and dripping from the bottom of the distributor. my guess is that it's a seal on the dizzy and i just wanted to double check if this is #6 in the picture below is the one i would replace. thanks guys
yes that would be the distributor o-ring which is notorious for leaking...also make sure that your valve cover gasket on the dizzy side is not leaking also...!!!
So everything that you're working with isn't filthy while putting on new gaskets. That's just me though, you can knock out the job in any way you prefer. I just hate handling greasy parts and then grabbing new gaskets.
brandonbarrios1
Mar 21, 2018 11:01 AM
DCAR
14
Jun 24, 2012 11:12 AM
mattsnooz
Dec 18, 2007 03:09 PM
