Brake light switch?
Old Mar 9, 2010 | 10:38 PM
jasoncanseeoh's Avatar
Default Brake light switch?
Okay, so I accidentally cut my brake light switch from my original harness. And I'm trying to rewire it up.
Here's my question:
(Brake switch is in center of picture.)
Is it okay to just run the white/green wire mentioned in the picture, THEN just have a ground to ANYTHING/ANYWHERE?
Or do I have to hook it up to the brake light FIRST, then ground from there?
To sum it up, white/green wire for sure...... then where do I have to hook up the ground? Is it okay anywhere or what?
Thanks for any help in advance!
Old Mar 10, 2010 | 07:22 AM
talkerty's Avatar
Default Re: Brake light switch?
I am kinda confused at what you are asking but ill do my best. There is a reason the grn/wht wire keeps going to the right side. It should go into the ECU. So, no you cant just hook the ground up anywhere. Is this a auto or manual by the way?
Old Mar 10, 2010 | 07:30 AM
^Yeah, I never noticed the green/white wire til just now...... damn, it's gonna suck having to rewire it.
It's manual, but not sure if that matters.
Good morning bump.
Old Mar 10, 2010 | 07:39 AM
talkerty's Avatar
Well for an automatic you must press the brakes to get out of park. I was thinking of why it would have to go to the ECU in a manual. For cruise control to turn off... its early thats all i could think of
Old Mar 10, 2010 | 08:32 PM
bump.
Old Mar 11, 2010 | 08:27 AM
g morning bump
mahgnibb
12
Oct 23, 2017 12:29 PM
jasoncanseeoh
Mar 11, 2010 08:30 PM
Padronis
Jun 29, 2005 08:13 AM
purpl7duece
Audio / Security / Video
Nov 18, 2002 05:47 PM
