What clutch for zc tranny?
Old Sep 8, 2002 | 08:49 AM
AudioXtremes's Avatar
Default What clutch for zc tranny?
I need to know what clutch to use with a zc tranny on a zc block. Thanks.
Old Sep 8, 2002 | 12:38 PM
wronghand's Avatar
Default Re: What clutch for zc tranny? (AudioXtremes)
It will all depend on what year ZC you have. You will use the clutch set for the civic/crx of the same year.
Old Sep 8, 2002 | 12:49 PM
FBPninetynineEM1's Avatar
Default Re: What clutch for zc tranny? (wronghand)
if you have the DOHC ZC i almost guarentee that its 86-89 integra, i know its not a single cam clutch for the civic or crx becuz i tried putting one in when i did the swap and it didnt work becuz the splines and the amount of teeth arnt the same.
Old Sep 8, 2002 | 01:48 PM
wronghand's Avatar
Default Re: What clutch for zc tranny? (TDRef9)
I can guarantee it is going to depend on the year of the engine tranny combo.
Here is how it breaks down.
88 - 21 spline 190mm disk
89 - 20 spline 200mm disk
90 - 20 spline 210mm disk
91 - 20 spline 210mm disk
Old Sep 8, 2002 | 05:38 PM
how do I know what year zc he has
Old Sep 8, 2002 | 06:43 PM
ScottEK's Avatar
its stamped on the exhaust manifold, two numbers like 90 or 88.
Old Sep 8, 2002 | 06:55 PM
Default Re: What clutch for zc tranny? (beta13)
is that all? because the exhaust manifold that was with it is gone.
Old Sep 8, 2002 | 08:32 PM
gregv's Avatar
I have a '91 Civic Si, and on my ZC the two-digit number is cast into the head on the exhaust side, not on the exhaust manifold itself;
it is also a '91. I ordered a '91 Civic Si 3-piece factory clutch, as well as the pilot bearing, and they were all identical to what came out of
the '91 ZC.
part numbers for 1991 Civic Si:
pilot bearing 91006-634-008
friction disc 22200-PM7-L01
pressure plate 22300-PM7-L00
release bearing 22810-PL3-005
It is interesting to note the PM7 designation in the friction disc & pressure plate
good luck
Old Sep 8, 2002 | 10:22 PM
Default Re: What clutch for zc tranny? (gregv)
thanks for all the help guys. I got it now
phatrick2332
Mar 31, 2004 06:11 AM
sabertooth
Jan 11, 2004 12:55 PM
ZColeon
Sep 5, 2001 11:49 AM
