Civic wheel bearing question!!! HELP
Old Mar 9, 2010 | 11:29 AM
civicSiR1.6's Avatar
Default Civic wheel bearing question!!! HELP
Ok I have a 1997 Civic. It has drums on the rear and I have a bad rear driver side wheel bearing. I know this for sure. It was checked.
So I have a called a local parts shop and tried to find a new wheel bearing and they told me $50 for the the whole hub assembly (used). The car is non ABs if it matters. Anyways ppl have been telling me even though i am getting the whole hub assembly that i still need to get the bearing pressed...is this true?
I plan on doing this as a DIY if it does not have to be pressed. So if it doesnt anyone got any suggestions or write ups..?
Any help is appriciated.
Old Mar 9, 2010 | 12:13 PM
delsolproblems's Avatar
Default Re: Civic wheel bearing question!!! HELP
No. The bearing is already pressed into the hub when you purchase it and does not require any pressing or lube. The biggest difficulty is getting the hub nut off. Make sure you've got a big breaker bar and socket for it and you should be fine. During installation, you'll torque that nut to 134 ft-lbs.
Old Mar 9, 2010 | 01:50 PM
98civdx's Avatar
Master Detailer
you may still need to heat it, we couldnt get my friends off at all, heated it up for a sec and it came off.
Old Mar 9, 2010 | 05:05 PM
Ok thanks thats awesome
eastbayrep
Feb 4, 2010 09:38 PM
z6hatchboy
Feb 6, 2009 06:31 PM
ryanstev
Dec 30, 2007 01:31 AM
spoolin_teg
Mar 8, 2007 04:26 PM
hawaiiangsr
Nov 21, 2006 12:36 PM
