p28 code 14
Old Mar 9, 2010 | 03:57 AM
b_hoov's Avatar
Default p28 code 14
been back and fourth with this car for a while now, 91 si with z6 swap, throws a code 14. hooked up my smoke machine and found a vacuum leak, fixed the issue, same thing, code 14, and when the manifold pressure equalizes it just spudders, revs and quits revs and quits, idles fine, only between 1200-1800 rpm does it happen and its only when pressure is equalized, if i am accelerating or idling it's fine. any ideas? pcm is good, no more vacuum leaks. just looking for thoughts and ideas here.
Old Mar 9, 2010 | 04:10 AM
ef-hatchcrap's Avatar
Default Re: p28 code 14
Have you tried a know good working iacv. Have you checked for voltage at the plug?
Old Mar 9, 2010 | 05:36 AM
b_hoov's Avatar
whats voltage @ the plug supposto be? i will be getting a brand new one friday.
xlusiveracer
Honda CR-V & Element
Jan 6, 2017 05:54 AM
TwoFacedCustoms
Oct 15, 2010 06:05 PM
HOODLOVER
Sep 20, 2008 08:51 AM
yz125rider21
12
Feb 12, 2007 04:49 PM
Supa_Slow_Civic
Jul 23, 2004 09:07 PM
