Suspension & Brakes Theory, alignment, spring rates....
CUT my shock towers now problem HELP
Old Mar 8, 2010 | 10:03 PM
builtsinglecam's Avatar
Default CUT my shock towers now problem HELP
ok i have a 98 civic ek 4 door and i CUT my shock towers and now i been through 3 axles . but every time i go over a bump the passenger side makes a lumpy sound when my boot rips and grease goes out. so what i want to know is, ARE the hydro axles different from cable tranny axles? can i use cable axles in my hydro tranny? i heard newer civic axles HAVE DOUBLE WISHBONE SUSPENSION. is that true?
*edited for clarity*
Old Mar 8, 2010 | 11:13 PM
TypeRMOBBiN209's Avatar
Default Re: cutted my shock towers now problem HELP
post pics
Old Mar 9, 2010 | 04:43 AM
96hb's Avatar
LOL! WTF? Maybe your car is too low and your axles can't handle it?
Old Mar 9, 2010 | 05:03 AM
jdmwannabee's Avatar
where did you cut your shock towers? are you sure you cut them in the right spot? is it both axles or only one that you're having a problem with? when you change them are you using remanufactured ones or brand new ones?
Old Mar 9, 2010 | 07:41 AM
milkmanLCA's Avatar
show pics and why did you do this
Old Mar 9, 2010 | 08:07 AM
stevieteg's Avatar
Let me guess. You also cut your stock springs in half and are riding on stock shocks.
Your ek has a double wishbone suspension, it really has nothing to do with the axles.
If you want to ride that low you'll probably need to cut the frame rails for the axles to clear. You might as well do it, you already ruined your car.
How does one come to the conclusion that cutting the shock towers is a good idea?
Old Mar 9, 2010 | 09:35 AM
ok pretty much i did this because cause i like riding dumped. and ive done this before so i did cut it in the right spot so im wondering if these axles only go so far down then then start grinding ok my question is can i use cable axles?
Old Mar 9, 2010 | 10:06 AM
stevieteg's Avatar
You're best bet would be to use whatever axle your trans is.
What suspension setup are you using?
People have run super slammed setups without cutting the shock towers, you just need really high rate springs.
If you're running that low there's a good chance the axles are hitting the frame rail. Have someone bounce the car and look to see if the axles are hitting the rail.
Personally, I'd just bring the car up a little bit, it would solve all of your problems.
Old Mar 9, 2010 | 04:28 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Alright, I did some house cleaning and editing for clarity. Let's try to keep this clean.
OP, do not attack other users or circumvent the language filters.
As for your axles, the double wishbone suspension design has nothing to do with them. Neither would axles from a cable-actuated tranny make any difference. Since you cut your shock towers, most likely the axles are now hitting the frame rails, as was previously mentioned. You have three options.
1. Raise the car up.
2. Use stiffer springs.
3. Notch the frame rails.
Any one or two of these options should solve your problems.
Also keep in mind that your shock towers are now weakened with the large holes in them. You need to box some sheet metal around them to add strength back in.
Old Mar 9, 2010 | 06:38 PM
thank alot thats what i was looking for thanks
Old Mar 9, 2010 | 06:46 PM
Chef Andre's Avatar
HT's TOP CHEF
Default Re: CUT my shock towers now problem HELP
I wanna see pics of this?
Old Mar 9, 2010 | 06:56 PM
jdm36's Avatar
+1
Old Mar 9, 2010 | 07:11 PM
1.5Slowmatic's Avatar
imacoolkid did this to his car. The green EM1. Im sure most of you have seen it.
Old Mar 9, 2010 | 08:10 PM
angel_i's Avatar
pics of said carnage...
Old Mar 9, 2010 | 08:34 PM
forcefedferio's Avatar
i still don't understand this one bit, i've had cars that were almost to the point of undriveable and i have NEVER had to cut anything. especially not something structurally important like my shock tower. this is just stupid.
in for pics.
Old Mar 10, 2010 | 08:21 PM
Community Builder
in for pics.
You probably had stiff@$$ springs. OP most likely does not, hence why the UCA was hitting the shock towers. Going too low with too soft a spring will do that.
Old Mar 10, 2010 | 08:23 PM
so instead of doing it properly, he cut a structural piece of his car apart...gotcha...he's a smart guy.
i have heard of the adjustable ball joint type UCA's hitting, but if your stock ones are hitting you have some serious issues.
Old Mar 10, 2010 | 08:33 PM
kaiba's Avatar
Hoping for pictures.
Old Mar 11, 2010 | 05:29 AM
Community Builder
numbskulls in this thread probably scared OP off
Old Mar 11, 2010 | 07:50 AM
yeahhhh, that or he was in a bad car accident due to his stupidy.
Old Mar 11, 2010 | 11:20 AM
overurhead360's Avatar
Post pics. Sound like "cutting" in general is dumb. post pics please so we can get a better understanding of this.
Old Mar 11, 2010 | 01:24 PM
Community Builder
There are pics around here in the slammed threads.
h4x0r3d way of doing it:
Being too low with a camber kit causes this:
This is how you do it right. Cut and raised the metal to add clearance while still maintaining stock-like appearance. I've also seen it boxed out, which isn't as pretty but probably allows a bit more room.
Shonda
Oct 18, 2006 07:57 AM
EeeJayEight
Jun 21, 2004 03:16 AM
highboostb18c1
Apr 22, 2004 10:26 AM
TypeRod
Aug 21, 2002 10:48 PM
