Tires getting sliced by inner wheel well after installing konis
I just replaced my stock shocks with koni yellows. Before the stock shocks had skunk2 springs and I used the same springs. I also used extended top hats for extra shock travel. But after the install the tires, mostly the passenger side is getting sliced by this metal sticking out running along the middle of the wheel well. Is it just the skunk2 springs are too low or maybe did I do something wrong?
And also it still sounds like a sledgehammer is banging my dashboard when i hit a bump.
I just dont understand why its super slammed like that. Is it possible that maybe the springs are not good anymore?
I have a 94 integra with skunk2 springs on koni yellow shocks on 16" GT3s with 205-45-16 tires
duh...I dont want it that low! i look on google for other integras with skunk2 springs and they are not slammed to the point the whole tire is tucked in like mine. Something is wrong I think.
On another forum, they said that it could be from maybe the springs in the front right now are supposed to be in the rear and vise versa. Does this issue sound like the spring placement is the cause?
if it's only coming from one side, then my suggestion is to check your rear trailing arm bushing.
and when you say springs, lowering springs, or coil over sleeves?
have u had your car aligned? or have camber kits on it? cuz my car is incredible low and i have to get it aligned to have it not tear my tires up like that. plus if u just got lowering springs and not adjustable one it sags down real low like that depending on ur tire size
yea i have skunk2 lowering springs. No i havnt gotten it aligned but my question is if my springs cud have been placed wrong on the car. (front needs to be switched with back?)
CNt be the top hats they dont cause the car to drop more. And the springs I think are in the right place because The wider coils are in the rear and the front are smaller. I think its supposed to be like that.?
I don't mean the size of the spring, I'm talking about the perch it goes on. On the body of the shock you should notice a couple of different spaces for the c clip to go. I'm not sure which one you should be using, but I remember a thread on T-I a while back where a guy had the spring on the wrong one.
trust me, its not that simple....
and tophats don't cause it to drop more, tophats are to extend travel when the shock is compressed, unless he's hitting bumps every 10 seconds, it wouldn't be the cause of his issue...
On the back the cup should have the open(Big) end upwards so that the spring sits in it. On the front the cup goes open (big) end downwards so that the spring does down over it.
Also, if you used the lower circlip lcoation on the Koni shocks, you'll end up with additional lowering, which could be causing the issue.
From the description of the banging sound, you could be hitting the UCAs into the shock tower, which can happen with extended upper shock mounts, as they allow additional compression travel. Verify that the correct bumpstop is being used, and that the bumpstop fully compresses before the UCA makes contact (you'll need to assemble the suspension without the spring to test this).
Remove wheel.
Remove shock assembly from car.
Remove spring and perch from shock.
Remove circlip (use gentle force and a screwdriver)
Re-install circlip in desired location (should be 2 grooves on front shocks, use the upper groove for "stock height". 3 grooves in back, use middle groove for "stock height").
Re-install perch and spring on shock.
Re-install assembly onto car.
Re-install wheel.
Repeat for other corners.
Get car aligned at new height (toe changes with height change).
Re-install wheel.
Remove wheel.
Re-install wheel.
Re-install wheel.
well, it's correct and it's probably the OP's problem. Nothing else could make the tires hit the shock tower on the Konis but not on the original shocks.
Yea it definitley is the problem..... so the perch circlip goes up to raise the car and the circlip goes down to lower the car correct? Right now its probably on the lowest perch. How much does the car lower or raise between each circlip ajdustment?
I'm a programmer. How long do you think it took to type?
(Honestly, less than a minute. I wrote 7 pages of code in the last 10 minutes, but IntelliSense makes that easy...)
Between 1" and 1.5" of ride height on an Integra. PatrickGSR94 can probably give a better answer here. Never touched my circlips, I have GC sleeves.
I have not gotten a chance to check if the circlip is the issue but what if I find that the circlip is in the normal position? What else could be the problem?
