Swap completed - Now tail Lamp warning light
Old Mar 8, 2010 | 07:00 PM
stellium's Avatar
Default Swap completed - Now tail Lamp warning light
Guys,
Much celebrating around the palace and the courtyard. I got the F22A6 started and connected in my 1993 Honda Accord EX-R. I had forgotten the O2 sensor and that was an easy fix along with bleeding the clutch line.
Now the last thing left is that the Tail Lamp warning light goes on and stays on. I'm pretty sure that all lights and such are functional. I'll double check just to be certain. Is there anything else that could cause this? More specifically, is the circuit board a possible culprit?
Any help would be appreciated.
Jacques
Old Mar 8, 2010 | 09:09 PM
nus_dogg's Avatar
Default Re: Swap completed - Now tail Lamp warning light
Have you check the bulb to see if they're the right ones? Otherwise, it must be something you did in the wiring.
Old Mar 12, 2010 | 10:48 AM
low-n-slow_cb7's Avatar
double check that all the lights are working correclty. My light has been on for over a year now and everything works fine, i've been trying to figure out why myself but its probably just a coinsidence that it popped up after the swap.
03civiclx
Honda Civic (2001 - 2005)
Jul 10, 2009 11:05 PM
FastKTJ
Dec 15, 2007 07:39 AM
thn116
Aug 12, 2007 07:14 PM
