95 civic with b18b bogging horribly
Old Mar 8, 2010 | 04:40 PM
95civic16's Avatar
Default 95 civic with b18b bogging horribly
i have a b18b in my 95 coupe and i just took the motor out to put a new clutch in and i put it back in and now it runs like **** if i give in more than a 1/4 throttle it will bog out there is no cels idk what the problem could be it ran fine before nothing is different but the clutch.
Old Mar 8, 2010 | 04:52 PM
Matt93eg's Avatar
Default Re: 95 civic with b18b bogging horribly
Check all your grounds in the engine bay.
-Thermostat Ground
-Transmission Ground
-Engine to Core Support ground.
You didn't happen to change the Cam timing or anything did you? Put on a new Timing Belt when you did the clutch, etc?
No rags or anything got left or sucked into the Throttle Body?
Old Mar 8, 2010 | 05:03 PM
-__-'s Avatar
-Thermostat Ground
rags in the throttle body would be SUPER CRAPPY. also check ignition timing
Old Mar 8, 2010 | 05:18 PM
Matt93eg's Avatar
No Doubt. I've seen it happen though. You stuff a rag in the throttle body to keep out dust, you go to put intake back on while your bullshitting with a friend and don't notice Mr. Rag hiding out by the butterfly. lol.
chineseflyrice
Jan 23, 2007 07:06 AM
Bakeoff
26
Apr 25, 2004 08:42 PM
uniqueclassics
Sep 18, 2003 11:57 AM
S13 slide
Jun 2, 2002 01:50 AM
