Transsmission case blows!
Can some please tell me what went wrong here
transmission-
1st-oem
2nd-brand new oem
3rd and 4th- mfactory pro series synchro set(straight cut)
5th-oem
I just finished putting in my brand new oem 2nd gear, took it for a spin.. No leaks every thing went fine.
Later that night.. Did a couple of pulls on the street just to see if everything was working properly, every thing felt good.
Today drove the car to work. Shifter had slight movement upon accelerating I figure I just forgot to tighten the rear motor mount. Come to find out I see the countershaft!! I am so sick to my stomach.
Im just wondering if anybody experienced anything like this..And what couldved caused this.
I did indeed call mfactory and they said that 4th gear tends to pull apart, hense the need of a handcuff. Makes sense.
I Just hope I didn't ruin the gears/shafts.
Please ht help me out !
Thanks in advance
mahalo from Hawaii-Justen
transmission-
1st-oem
2nd-brand new oem
5th-oem
Thanks in advance
umm,I'm going to take a stab in the dark here. You JB Welded a tranny case, then tig welded it and wonder why it went kaboom? I'm going with damage prior to gear install.
Thanks guys For all the feedback.
Case took normal time to install.
Im sure it's something that has to do with the case, or not having a cuff?
The reason I say this is because when I had the jb weld on (before the tig) I never had such a problem. Maybe tig welding the case warped it a LiL bit. Who knows I just wanna get it fixed but wanna know before buying another case. I mean what are my options? Buy a new case and a handcuff and see if it blows?
Well see the thing is , I just bought brand new mfactory hlhs bearings just to make sure I wouldn't have problems.
Man I hope the bearings and gears are still good..
I guess it has to be the welded case..
Im getting another case already and I guess Ill order a cuff.. Can any body show me where to get a Cuff.. ?
Guest
Posts: n/a
Thanks for all the replies. Still didn't get a chance to overhaul the damn thing. I had no Problem getting the snap ring to close. I mean this is like the 5th time I took the trans apart with no problems. So I know how the every thing is supposed to close up. I really think it could be the tig weld and not having a cuff.
I will diff, take pics and post them. Im getting another case and ordering a liberty handcuff first thing tomorrow morning!
Has any body ran these straight cut gears with out a cuff? If so, any problems?
Straight cut gears increase radial loads, so the gears will push apart more than they would with a Helical gear. It is highly recommended to run a 5th gear brace.
You need to check the clearances on the countershaft.... Im positive you had to pull up on the bearing too much for the snap ring to pop in.... Happened to me several times.
96hatchBoy
Apr 13, 2013 08:10 PM
extralargenog
Northwest (Sales)
27
Nov 29, 2008 04:22 PM
