Rear LCA and Upper arm compatiblity
As I understand the rear lower control arm from a 94 integra should fit a 95 civic. correct?
I am also trying to find out if the rear upper control arm for a 95 civic is the same as a 91 civic.
I am asking because I did a rear disk swap on my 95 civic, and it appears that there is some camber issues that were not there before, namely positive camber on at least one wheel. if all the parts are in fact compatible i am going to assume that i probably have a bent component.
any answers or input is appreciated.
Thanks.
Thanks.
i dont think anything is bent...i think i remember reading somewhere that when installing the integra trailing arms the upper arms are longer or shorter, i dont remember. so it makes it unaligned. have you read about the washer trick for rear camber?
i know of the washer trick, but my wheel has positive camber, ie tilting out not in it appears to be more on the left side then the right but i have not had a chance to really measure it. the washer trick wouldn't work for that.
im almost positive the LCA's are the same because all the aftermarket LCA's fit both the civic and integra.
Sinitron
Northeast (Sales)
30
Sep 3, 2010 02:49 PM
FaNiO
Oct 11, 2009 06:36 PM
