Camber kits...which one is best?
I need some advice on what camber kit is best...i have look at the skunk2, buddy club, and blox...which one is the best one? I lowered my teg and i need the kit for the front but would it be a good idea to also get the rear?? Ill be ordering the kit tonight after i get out of my college class so please give me some advice thanks...
From the suspension forum:
Sticky: No, you DO NOT need camber kits!!!!!!!!
Can you explain why you say you need them for the front? Keep in mind that toe causes the majority of tire wear after you lower a Honda, not negative camber, and a simple alignment where the toe is set to factory specs is really all that's needed to prevent excessive tire wear.
ill post pics tmrw....the driver said is fine but the passenger side is tilted outwards at the bottom part....i took it to get the front alignment and check the tie rods and the dude said he nvr had a car that was so low...and his equipment to align my car wouldnt work bc it was hitting my exhaust...i guess i could raise it sum and adjust the toe to pull it in
I usually have to remove my front bumper to give the lasers a clear path across the front of the car. Sucks but I just deal with it.
Skunk 2 Pro Kit is what I was told was a great kit when I bought mine. They are good I guess, they were able to camber my car correctly at firestone.
I would def buy a kit though even though some people say not too. My buddy had his teg lowered 1.5 inches in the front and after 15k or something on his tires the inner part was shot, while the outer was fine. **** my tires don't last 12k and I have a camber kit, I drive like an *******.
Camber kits are more trouble than they're worth. See my thread that TunerN00b linked to above and you'll see why.
Yup.
I got 32k miles and perfectly even wear on a set of Toyo Proxes 4 tires, running -4* of front camber (-1.3* rear).
I also have dented shock towers thanks to the damn "camber kit", and I was using one of the thinnest camber adjusting UCAs out there (SPC).
Camber doesn't kill tires. Driving like an ******* does though (my track tires don't wear very nicely
Your buddy needed an alignment or had other problems. I have about -2* camber, and had even more when I was lowered over 3" on GC's, and I get at least 30K miles on a set of tires. My last set was on the car for 2.5 years. No camber kits at all.
Don't get a cheap one or this may happen...
These were some no name brand ones were on my car when I bought it and this happened when I was driving down the road. I'm lucky I wasn't going very fast and was right near my house.
Heres a link to that thread...https://honda-tech.com/forums/acura-integra-6/upper-ball-joint-broke-2571876/
Install a camber kit only if you need to run more negative camber than lowering alone provided. Reasons to need more would be fine tuning on track performance, or to fit very wide and/or low offset wheels.
I'm going to go with no camber for now...I just need to have the toe adjusted I guess??? I'll try to get a pic up soon so everyone can see what is going on with the passenger side...it's wierd bc the driver side is fine but the passenger isn't...
i had the same problem with my car. i was running at stock height with stock ls mesh/web wheels. and the inside of the passenger side tire was in bad shape. well i just bought some 17" enkei ev5 wheels and 205/40-17 bridgestone potenza tires and there was too much of a wheel gap so i lowered it with some eibach pro lowering springs and i do not need a camber kit all i needed was an alignment. i will post up pics soon.
Do NOT listen to this guy.
If your going to get a camber kit I do not suggest cheaping out.
I just installed a buddy club front and rear camber kit on my RS. Quality is great. I would either choose skunk2 or buddyclub. IMHO.
I actually purchased my camber kits so I could adjust my degrees of negative camber for track day's / etc. With -2 degrees camber in the front and -1.3 in the rear and 0 toe all the way around the car feels amazing
GL!
GL!
Hahaha
Maybe you should read the thread
https://honda-tech.com/forums/showthread.php?t=2571876
