integra brakes for my eg
will the fronts and backs bolt right up on my 94 hatch?
guys parting out a 94 gsr. and id like to change my rear drum set up
need to know exactley what parts i need for the rear end. and if the fronts will work
guy also has front lower control arm and sway bar i need.
my eg has no sway and was told id need integ control arm to run sway on my car.
thanks for any help here folks.
yes, the front & back brakes will bolt on
take the entire rear trailing arm, brakes, cables, brake hoses; it'll bolt right up.
you'll also need the teg's rear lca (if you're planning to install the teg's rear sway) since your 94 civic HB's rear lca's might not have the holes to accomodate a rear sway bar
take the entire front knuckle assembly, brakes and all
a. keep the brake booster from your 94 civic HB & use a bigger master cylinder from a 90-91 civic EX
b. grab the m/c & booster from the integra
when swapping out suspension parts, you'll need to get an alignment
thanks for the reply and the info.i just put my coilovers on and had alignment done yesterday.
my coilovers came with lca's. so they where just put on in the rear.
im hoping to get the parts from kid.
he said he has front and rear brakes, front contorl arms, knuckles, not sure if he has front sway.
im planning on doing an asr combo, brace and rear sway.
waiting to hear back from kid on package price for all the parts id need for swap
thanks again for the needed info.
rear disc brake conversion for $250 and the front lower control arm, the sway bar, the steering knuckles with wheel bearings, and front rotors, calipers and pads for $250. So $500 for everything
that sound like a good price for the parts??
rear disc is about rite they usually go 250, make sure it has the e-brake cables on it...
and hes pretty much giving u the front end for 250 thats both sides rite???
steering knuckle u mean tie rod??
id go 250 for the rear n 200 on the front **** unless it includes the rack n pinion
think i might be getting it all for 450
sway bar, lower control arms i need for sway, front and rear brake set ups, pretty sure rotors are slotted not stock,knuckles with bushings or bearings...not sure what they are or if i need, but y not uh... might help
hell yea 450 take that **** in a heartbeat bro, im also looking for that kinda set up for my hatch
well i picked it up this morning. taking paint off cali's to repaint prior to install. but i came across a tread where a guy says it almost unsafe to run my new set up without, master cylender, brake booster, and 40/40 prop valve!!!
is this true?
i had priced drilled and slotted rotors for front with pads and stock rear set up
came to close to 300
i figured for 450, get all disc brake set up. better than my stock, set up came with new pads, and drilled/slotted rotors. thought i was ahead here.
now i need 3 more parts??????????
not sure price one these parts, or where to find.
guess i can track em down.
id just like to know if i need all 3
thought i could just stip and respray cali's and be good to go.
guess not.
is this true?
guess not.
you will definitely want the bigger master cylinder, i've heard the 15/16 one works, I used the 1" one from the gsr with the brake booster and it works great.
rather have everything put in once, right, with rite parts
thanks for info and help folks
link below to b18c5-eh2's thread,
"Easiest Brake Master Cylinder Upgrade Yet for 1992-1995 Civics..."
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/easiest-brake-master-cylinder-upgrade-yet-1992-1995-civics-364783/
cool. ill check into that
but the kid that sold me conversion has the master and booster. 60 bucks.
thn all parts match and would only need 40/40.
am i right?
worth hour and half drive?
or should i just get civic part?
am i right?
when upgrading brakes do:
prop valve, master cylinder, booster all at one time. best you can do finish it one time and then it's done for good. doing short cuts is just nonsense..
for civic upgrade 90-91 ex booster, master cylinder, prop valve, get some nice rotors pads, and tires and car will stop like M3.
do you have any pics of this,,im interested..i have to replace my brakes,,especially the Brake Disc as soon as possible..
