idle problem
Old Mar 8, 2010 | 09:46 AM
vteckyle's Avatar
Default idle problem
i just traded my eg for a ek its a 96 dx , it has idleing problem. it revs high to low high to low when it warms up is it the egr valve?
Old Mar 8, 2010 | 09:50 AM
4g4dcruisin's Avatar
Default Re: idle problem
What engine is in the car?
Have you checked your coolant level? Then bled the air out?
Are you familiar with the IACV and FITV? If so, clean them.
If there is a swap, what ecu are you running?
Auto or 5 speed?
Old Mar 8, 2010 | 09:51 AM
lome1232's Avatar
sounds like it, it might also be a vaccum leak, i had the same problem on my vehicle and it was leaking at the head and IM. When it was warm i guess the metal softened and had a vaccum leak.
Old Mar 8, 2010 | 09:52 AM
lome1232's Avatar
replaced the gasket and problem solved. Try the EGR first and then look for something else.
bluelsvtecda9
Jan 21, 2007 11:27 PM
ek_chris
Sep 21, 2006 11:15 AM
swads21
Jul 3, 2006 06:38 AM
h-bomb
May 20, 2004 05:33 AM
