Widebands. Best bang for buck on accuracy
Old Mar 8, 2010 | 08:59 AM
RedneckRicer's Avatar
Default Widebands. Best bang for buck on accuracy
Im the hunt for a wideband. Im looking for one that is fast and accurate. But so many are on the market i dont know which one to go with. dont have a big wallet for it. needs to be able to work with S300.
Ive heard the PLX and AEM have a slow response.
Please share you input on what sensors you are using.
Old Mar 8, 2010 | 09:18 AM
turbodano's Avatar
Default Re: Widebands. Best bang for buck on accuracy
Pay for a good one that uses the Bosch chip. Pro logger or Fuel Tech both use it and don't eat wide band sensors.
Old Mar 8, 2010 | 09:20 AM
raene's Avatar
Just curious, what are your opinions on the 14point7 wideband offerings? Have you used them? ie., JAW, NAW.
Old Mar 8, 2010 | 11:24 AM
JJsMotorsports's Avatar
Ngk all day
Old Mar 8, 2010 | 11:40 AM
PrecisionPerformanceParts's Avatar
ngk with ntk sensor upgrade
Old Mar 8, 2010 | 11:57 AM
twkdCD595's Avatar
My vote is also for the NGK AFX... I really like mine. Also can be recalibrated for either the Bosch or the better route is to upgrade to the NGK NTK sensor.
Old Mar 8, 2010 | 12:13 PM
tepid1's Avatar
Anything that uses the NTK sensor.
Old Mar 8, 2010 | 01:54 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
AFX by NGK....I had to go look in the garage at it. I bought this one from t1. It's dead on with Tony's Motec wideband. The moted just has more range
Old Mar 8, 2010 | 02:17 PM
Chef Andre's Avatar
HT's TOP CHEF
Anyone every use the Glowshift gauges wideband? It comes with a Bosch 4.9 sensor and has a pretty nice warranty.
Old Mar 8, 2010 | 02:56 PM
tepid1's Avatar
The Bosch's burn out rather quick with leaded fuels.
Old Mar 8, 2010 | 03:29 PM
xenocron's Avatar
Widebands are just another tool people...you can spend all of the money in the world on one that meets NASA spec or you can get one that just works every pass down the track (until its time to change the sensor...a wear part).
Your car has a WIDE window of power, so Air/Fuel ratio in the grand scheme of things isnt all that important as long as its close. If you are logging at the track, all that matters if you see a change in AFRs is why that changed and did it make you faster or slower. Being accurate isnt important here...but consistency is.
With that said, my preference (bang for buck) has always been with the Innovate products...ever since they shattered and opened the Affordable wideband market when they came to the table. PLX is my second favorite. AEM is my LEAST favorite.
Old Mar 8, 2010 | 03:43 PM
mike93eh2's Avatar
mine has lasted 4 years so far on nothing but race gas..and i drive this car every week.
i vote for PLX.....
Old Mar 8, 2010 | 06:36 PM
turbo90accord's Avatar
prologger is my choice.
Old Mar 8, 2010 | 07:01 PM
spoolin hatch's Avatar
I like my FJO with ntk sensor. Had an AEM but sensor didnt last long (2 pulls on dyno) on leaded fuel.
Old Mar 8, 2010 | 07:03 PM
85mmek9's Avatar
I love my FJO, works great and have never had a problem.
Old Mar 8, 2010 | 07:05 PM
dester223's Avatar
I'd have had great luck with the PLX M300, and use a ton of AEM widebands.
I had my AEM in my car for a couple years on the same sensor. Seems if you run leaded race gas, that you gotta beat the **** out of it, or the lead will deposit on the sensor and kill it.
Old Mar 8, 2010 | 07:15 PM
Turbo-charged's Avatar
fjo is the best affordable wideband ive ever had. the ngk is good for the money. aem isnt very good. i havnt had good luck with innovative but havnt used one in several years. plx seems to be ok. i think the all time worst is the damn dynojet wideband haha
Old Mar 8, 2010 | 07:32 PM
4piston's Avatar
In true DSM fashion...Look in the rearview and lean her out on the AFC til you don't see smoke anymore. Perfect AFR.
Old Mar 8, 2010 | 08:32 PM
t66crx's Avatar
PLX DM-5. thing runs great. PLX all the way
Old Mar 8, 2010 | 08:49 PM
ALLMOTOR18's Avatar
I've had the best results with the Prologger..
Old Mar 8, 2010 | 08:56 PM
AcuraIntegraLS-T's Avatar
I use the Innovate, and if sensors are scaring you away, buy one from vatozone and it has a 1yr warranty @ $52bux If your not looking to spend a lot get the LC1 and run it through your s300 and through your computer then there is no need for an external gauge so you will save some money there
Old Mar 8, 2010 | 09:01 PM
Sir2egk's Avatar
how about with E85?
Old Mar 8, 2010 | 09:21 PM
extremeracer's Avatar
Why do you say the Dynojet is bad ???
I'm running one on my Methanol fueled LS/Vtec Turbo - is this a problem ??
Last time I checked it against the Autronic lambda and Dynapack lambda it seemed very close !!!
Old Mar 8, 2010 | 09:24 PM
Bigmac88's Avatar
This
Old Mar 8, 2010 | 09:57 PM
Kevin's Avatar
I like my Innovate LM-1...before that i had a PLX r500 but the screen **** the bed and i haven't had a chance to ship it back to be repaired which is going to cost $80.
