SC61 vs PRECISION HP6262 BILLET TURBO
I have a 60-1 right now with the extended tip on it. It is the 60-1 with ar63 housing. I am about to finish up my car.. but i am thinking that i should buy eithier a sc61 or a Precision billet turbo.. I am wanting to make a min of 500.. but i want to be able to get 620ish. I know this is a lot.. but this is just want i want. I do understand that the sc61 will do the job for 500ish.. but after its coming close to being maxxed out.. I have been seeing the sc61 and the precison turbo's go for the same price.. so that is why i am wondering which one i should get if they are about the same price($899.99) Well that is what i am seeing how much the precision turbo's go for at http://www.kineticmotorsport.com/cat...RBO-305-1.html.
The car is going to be a street for the most part.. but i will go to the track when i get my lsd!!!
My setup:
B18c1 sleeved
ls eagle rods
arias pistons(ls)85mm
ls crank
b16 head with gsr cams
spoolin ramhorn manifold and 3" downpipe
My setup:
B18c1 sleeved
ls eagle rods
ls crank
both are great turbos. matched well with your setup either one will do the job. the sc61 doesnt max out shortly after 500. i think they are rated to 700+ but with the larger exhaust housing. the sc6262 is putting out great numbers right now. on pump a buddy of mine just put out 540 and over 700 on race with plenty of room left.so just pick you poisen. i recommend the 6262.
899 for a billet wheel journal bearing turbo is a good deal. its abotu the same price as a sc61 and will outperform throughout the powerband and peak power
I am thinking the same thing.. I might be happy with 500whp.. But if that is the case.. I have a turbonetics 60-1 with the extended tip.. It is has a ar 63 housing on it.. It is not really big at all.. but i can make 500whp on it.. I was just wanting to get a turbo that can make more power.. if i need it.. or I guess i should say want it.. lol.. I don't know what 500whp feels like.. but i am going to be happy... reguardless of what i get..
The 6057.. does sound good.. The real thing that i like is options meaning. not much limitions.. you talk about spooling wise( I know that all motors are different when it comes to how turbo's react to it, but how is the 6057 on a 2.0L gsr..?) Do you have an idea.. thanks in advance...
i know that the extended tip did not come on them.. the person that i bought it from welded it on there.. i am not the much of a noob
yeah.. i would like the 6057.. if i get one.. cause.. i want more power than what the 30r produces.. just in case i want more power
I think the 6057 actually might be discontinued, I heard something about it before and it just came to mind. The 5857 will easily make more power than a 3076R, the compressor is far better. Ive seen one make near 600whp in an Evo.
95BlkGSR
May 19, 2009 04:47 PM
