Using an Si cam in a D15B1
Old Mar 8, 2010 | 07:26 AM
Fo-Do Fanatic's Avatar
Default Using an Si cam in a D15B1
I just picked up an Si cam since I know that the B1 cam is far inferior to the Si cam. I've read that I have to have a Y7 or Y8 cam gear to put on the Si cam to compensate for the 3mm deck heighth difference from the d16a6 compared the the d15b1. I have the Si cam gear with it as well. Just incase I could've used that without a problem.
Can anyone verify this? Or can I just throw it in and go?
Old Mar 8, 2010 | 09:51 AM
whoa its len 2's Avatar
Default Re: Using an Si cam in a D15B1
D15 and D16 cam gears are the same. The 88 Si cams are indexed the same as D15 cams. 89-91 Si cams are indexed differently and the Y7/Y8 cam gear will zero the cam back to TDC. Dont forget to set the valve lash when youre done.
Old Mar 8, 2010 | 10:37 AM
Sooo, your saying I have to use one or I don't? The cam is out of a 91 Si. As is my car a 91 as well.
Old Mar 8, 2010 | 11:59 AM
Yeah use a Y-series cam gear with a 91 Si cam.
Old Mar 8, 2010 | 12:01 PM
Alright cool thanks man!!
Old Oct 5, 2011 | 02:49 AM
19EF90's Avatar
would a z6 cam gear work dos anyone know.
Sheep
29
Apr 2, 2007 11:01 PM
bennyhonda7
Jun 7, 2005 02:11 PM
GreenMachineRex
Mar 7, 2004 02:39 PM
TylerB
Jan 17, 2004 08:24 AM
dgonzals
Jul 7, 2003 05:28 PM
