93 si hatch.door/headlight chime,sunroof,dome light dead
Ok.as stated above.its a 93 hatchback.si.
Door chimer
Headlight chimer
Sunroof
Dome light
They don't work.I can hear a click when sunroof button is pressed.
The ignition is wired to a push button.doesn't start when I press clutch.I have to turn it like I was turning it on then I gota press button to start.
I've tryed googling but I can't find much.I think I saw somthing several months back(I wasn't concerned with it cuz I had to fix other stuff).but its had to d somthing with ignition switch.could this be the problem?reason for it was bypassed or watever to a push button?
Any ideas what too look for would be appreciated.
Door chimer
Headlight chimer
Sunroof
Dome light
I don't have the fuse panel so I don't know which it is,but I borrowd one off an ex coupe.and replaced the fuse were its located,but yet come to find out there's fuses n just about all the slots..I doubt it needs em all cuase the ex diagram showed a whole lot less.I also pulled and checked every single one twice or thrice times amd the underhood fuses..also I chekced the wiriinng to the sunroof motor.its all there.cuase previous owner said he got the glass replaced so I thought it was maybe unhooked.
I already tried unhooking the push button wiring and nothin.its plugged to the fuse box-switch-to starter..
I imagine its somthin stoopid.think ima try the ignition switch,I found 1 at a junk yard several weeks ago,he said 15.
If not that then the switch to the clutch,but I doubt thall have anything to do with dome light and headlight buzzer thingys
Hold up!!
Is there even a door/headlight chimer on 92-95 civics???
Lol I just looked at this ex and turned on headlights with key in the ignition. And it didn't beep..lol
Also with door open...
Am I trippin and thought they had 1??
I was just about to post asking if you're sure it had a door/headlight chime in the first place. 92-95 USDM Civics have a "you left the key in the ignition" chime, but not a door or headlight chime. I wish they did though.
fm
fm
Haha....damn then I was trippin...
Ok so.I'm guessing it should be somthin to do with ingition switch.
Cauuse my "you left the key in the ignition" chimer doesn't work lol
OEM retrofit. Not a buzzer from Radio Shack like most ppl do.
Hatpin
Jul 15, 2011 09:34 AM
