98 gs broke down on the GS parkway, doh!
Old Mar 7, 2010 | 09:41 PM
pliskin679's Avatar
Default 98 gs broke down on the GS parkway, doh!
so i was driving and it kinda just stalled. i pulled over and tried to start it again and its very inconsistent with it turning over, it will be fast one second then slow then fast again. i got it towed home and i tried to start it and it back fired twice then continued to be very inconstant... so its getting spark and fuel. i havent really looked at it yet i will in the morning but my guess is my timing belt skipped a tooth? its on there and tight so idk. FML guys, PS: garden state parkway towing is ****ING EXPENSIVE
Old Mar 8, 2010 | 12:50 AM
PaulMc's Avatar
Painfully Stupid
Default Re: 98 gs broke down on the GS parkway, doh!
What mile on the GSP did you break down? There are only two companies who are authorized to tow on the GSP, and it's always very expensive. Curious as to how many miles your tow was for and how much.
Old Mar 8, 2010 | 01:06 AM
94GSRMR's Avatar
maybe timing or relay check your fuses..
Old Mar 8, 2010 | 09:05 AM
pliskin679's Avatar
i was at 168 amd got it towed to nanuet/spring valley in NY which is at the very top of the GS parkway, it was like 4 miles and cost me 135 bucks
Old Mar 8, 2010 | 09:11 AM
pliskin679's Avatar
whicvh fuses might be popped?
Old Mar 8, 2010 | 09:40 AM
94GSRMR's Avatar
Check both underdash and underehood, just get a fuse puller and get to pullng
Old Mar 8, 2010 | 09:48 AM
milkmanLCA's Avatar
check your compression, head gasket break between 2 cylinders will cause an inconsistent turnover
Old Mar 8, 2010 | 09:58 AM
milanoteg's Avatar
Check for spark again, if there's little/no spark, i'd say distributor cap and rotor, which is an inexpensive fix.
Old Mar 8, 2010 | 10:19 AM
pliskin679's Avatar
thanks guys, im going to start working now thanks for all the advice, keep it comming :D
CorbenM
Aug 24, 2017 11:41 PM
ngh98civic
Feb 28, 2013 04:16 AM
peAches yO
Apr 29, 2011 09:52 PM
boobie1721
10
Dec 18, 2007 03:56 AM
CTRwannaB
13
Mar 29, 2004 08:11 AM
