LS/VTEC
Old Mar 7, 2010 | 09:26 PM
UltimateGayness's Avatar
Default LS/VTEC
Well I'm looking into building an LS/VTEC for my EF. I just purchased a a1 bottom end that was rebuilt with 0 miles. I was thinking of running p30 pistons with a b16 head. are ARP rod bolts and head studs required? will i be okay with oem bolts?
also what about balancing the rotating assembly. I'm trying to keep this cheap, so if I don't have to do that, would be best. any advice/input is appreciated..thanks!
Old Mar 8, 2010 | 06:50 AM
092eg6's Avatar
Default Re: LS/VTEC
head studs are not require altho it would be nice to get it, but i would invest in a set of arp rod bolts! dont cheap out when it comes to rod bolts, one little stretch and there goes your bearing and crank! balancing the rotaing assembly would be a good idea, because at high rpm the engine cause lots of vibration, but also not require to do!
Old Mar 8, 2010 | 06:05 PM
Default Re: LS/VTEC
Word, thanks for the input. i'll get a set of the rod bolts. i looked em up and they're cheaper than i thought haha
turb0teg
Apr 28, 2010 05:27 PM
Civichatch2k
Dec 26, 2004 10:32 PM
ea_hatch
Dec 19, 2004 09:53 AM
KillaB-
Sep 19, 2004 11:49 AM
rough_draft
Jul 9, 2004 03:14 PM
