PROBLEM W/ HIDS!
Old Mar 7, 2010 | 07:32 PM
jake00si's Avatar
Default PROBLEM W/ HIDS!
So all of the sudden my passenger side headlight works only half the time. When I go to turn my lights on..either it comes on or i just keep trying a few times till it does come on. It doesnt however flicker once it is on which leads me to believe there could be a problem with a relay or something. Any ideas or suggestions would be appreciated
Old Mar 7, 2010 | 07:42 PM
forcefedferio's Avatar
Default Re: PROBLEM W/ HIDS!
is this a retro-fit or is this a plug and play kit from ebay?
Old Mar 7, 2010 | 07:44 PM
Civicfanatic_09's Avatar
sounds like a ballast is trying to crap out.
Old Mar 7, 2010 | 07:49 PM
jake00si's Avatar
I honestly couldnt tell you, they've been in the car since i've had it. They're hid's retrofitted into ctr headlights..thats pretty much all i know. I've never messed with hid's so im not familiar with how they hook up and what not.
Old Mar 7, 2010 | 07:51 PM
Switch the ballast around and see if the other light does the same thing.
Old Mar 7, 2010 | 07:56 PM
yeah it sounds like a ballast, if it's a cheapo PNP kit they are notorious for bad ballasts. post pics of your setup.
Old Mar 7, 2010 | 08:02 PM
jake00si's Avatar
will post pics tomorrow when its light outside. and wtf is a ballast?! haha
Old Mar 8, 2010 | 04:11 PM
94H22EG's Avatar
sounds like a relay problem, im on my second relay kit w/ my HID's and im havin the same flicker problem, i have to shake the wires and they come back on...
Old Mar 8, 2010 | 06:22 PM
96honda_EK's Avatar
Ok a ballast is a little metal box that is the brain of the HIDs. Its what lights it up. No ballast = no HIDs. Look in your engine bay area. It shoud be bolted up somewhere to an empy area. The wiring from the light bulb should go into the balast. Just unplug it and unbolt the balast and switch it to the other side. Plug everything back up and see if it still does that
Bizzle5OH3
Lighting
May 15, 2011 06:55 PM
dth0ng69
Oct 15, 2009 07:21 PM
97ekcoupe
Mar 23, 2007 04:28 PM
spoon-eg
Feb 19, 2005 08:10 AM
B00STeD
Dec 11, 2002 10:16 AM
