LS Vtec Swap in Hatch Wont Start!!
Old Mar 7, 2010 | 06:04 PM
rtuner's Avatar
Icon3 LS Vtec Swap in Hatch Wont Start!!
Hey everyone I have a 94 Civic Si hatch with a b18a swap, ls vtec and a few other mods Tuned on S100...
Problem: Car wont start for a few days then it will start? Its very finicky, at first i was thinking the fuel pump but it will run fine for a few days then not start for another?
I am suspecting wiring? I have problems with a tach skitz and was wondering what could cause this...The swap has wires all over the place so this is why i assume wiring?
Changed the fuel filter and nothing better...
It smells of fuel
Any ideas
Thanks
Old Mar 7, 2010 | 06:45 PM
honda_hackett's Avatar
Default Re: LS Vtec Swap in Hatch Wont Start!!
buy a legit wiring harness cuz thats prob your problem. maybe a ground? during the times it doesnt start check your fuel line and make sure your gettin fuel.
Old Mar 7, 2010 | 09:39 PM
SVickstc's Avatar
was thinking a ground could cause it it is getting fuel
Old Mar 7, 2010 | 10:05 PM
ekb16's Avatar
grounds will cause ur car not to start. make sure you have the 3 main grounds hooked up, valve cover, t-stat housing and tranny gounds
Old Mar 8, 2010 | 07:58 AM
SVickstc's Avatar
Thanks I will check that today
could this be a main relay problem too?
Old Mar 8, 2010 | 08:52 AM
itsnotfast's Avatar
Maybe a stupid question.. What dizzy are you running on which head? Should be an OBD1 and match the head. I have seen the wrong dizzy cause this before.
Old Mar 8, 2010 | 08:53 AM
itsnotfast's Avatar
A faulty main relay would cause your car to not get fuel.
Old Mar 8, 2010 | 10:53 AM
SVickstc's Avatar
Gsr head obd1
Old Mar 8, 2010 | 11:25 AM
itsnotfast's Avatar
Originally Posted by SVickstc
Gsr head obd1
OBD1 GSR Dizzy as well?
1990CRX-si
Jul 31, 2012 05:20 PM
preludeNApower
Jan 13, 2012 06:43 PM
MPF_supra
Jul 22, 2007 10:17 PM
LScivic_wpg
13
Feb 9, 2006 01:49 PM
