civic brake calipers
im wondering if my calipers on my eg are no good.....
i change my rotors and pads and also bought Brake Caliper Kit from autozone and got that changed to about less dan 2 weaks ago ..i bearly travel far ....when im braking its sounds sorta like a spongy noise slash squick its hard to explain but im 100% sure its coming from the driver side brakes
anytime you replace your calipers (or remove your brake hose), you introduce air into your brake system; which results in spongy pedal feel
did you bleed your brakes after you replaced the calipers, pads & rotors?
if not, pick up some brake fluid, follow bleed sequence listed below. keep your eye on the master cylinder, don't let it go dry & keep it filled w/ brake fluid
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
Vagitarian
23
May 8, 2013 09:38 AM
Vagitarian
Suspension & Brakes
Apr 13, 2013 10:19 AM
Jizzmaster Zero
17
Mar 3, 2007 10:04 PM
icedlee
May 6, 2005 03:54 AM
